EZ2FLEE
Everything posted by EZ2FLEE
  1. What shock length is most beneficial for a +2 +1 arms, and a +2 swinger .... Thanks, Bob
  2. I'll trade ya Thor chest protector for that stabilizer
  3. I don't mean to high jack a thread but I'm in the middle of upgrading as well, would a inch or two longer shock on a +2 +1 ARM setup allow more travel or just more of a plush ride? Or are the stock shock lengths fine if built for that application.....
  4. Will durablue axle work with lsr carrier or vise versa? And is there a +2 x +2 lsr axle?....... Will brake, and sprocket hubs mix and match......any info appreciated
  5. All I needed to know, I'm goin one piece cuz it looks cleaner
  6. :................
  7. Is there a difference? Does one do something the other doesn't or is it just a preference thing?
  8. As far as domes go I read that for every 1cc u go down u add 8-10 lbs compression..?... If that's so is there a cut off point between 110 and alky....like there is a cut off between pump and 110 or doesn't it matter?
  9. So I would be better off running a 28mm flat slide or 30mm
  10. K I didn't know wether or not to keep the 8s or not running 110, and if you read the post its says it is ported..... I wasn't sure about the 16s that's why I was asking my baseline was 17s......I think that will be plenty......
  11. Ok the bikes current setup is stock stroke, .040 over pro lites , noss cool head 20cc domes, +4 timing stock carbs, boyeson pros, tors removed.......looking for lots more this winter was thinking 33mm flatslides, 16cc domes, nology coil and wires, +5 timing, crank work, billet intake, dual pingel, switch to a br9 plug.....and run 110.......:..also if I'm mixing 40:1 dominator w/ 93, would I still mix 40:1 with 110?
  12. Oct 22 went to silver lake, bike ran excellent, right up until the end of the day..... Tossed a ring on right side, so shees torn down and I'm gonna be sending the crank to passion for weld and true...... My question is @ 1300ft can I get away with 16cc domes on 110? ......or due to the fact that I'm running T5s and a Chris merry trail port would some custom cuts be of benefit? If anyone has any input its appreciated.......... The bike is a all around ride trail,dunes,hills...ect......thanks
  13. Mild shift kit, built by Dan Ellis out of fife lake auto Chevy bellhousing, was bolted up to my 350 Chevy which I still have the block and heads and misc other parts
  14. I have a turbo 400 2wd trans with only a cpl miles on it, ill trade for Banshee suspension parts, +2 +1 arms w/ shocks , +2 swingarm + shock , +2 durablue axle , maybe a set of nice engine cases and cylinders can be empty cases ...30 mm flat slide carbs, just some ideas what ya got
  15. Yup 25th is my bday I'm riding all day
  16. Can you do $200 shipped on the swinger to 49601? And is it set up for stock shock?
  17. Anybody?
  18. I just worked on a bike like this, turns out it was the flywheel
  19. Is this stock length? Pics?
  20. Cool It's all more or less a peace of mind thing
  21. Nah to big, I just need paddles right now
