domestic_beotch
Everything posted by domestic_beotch
  1. Thanks. All the grinding was done outside and the bike and my truck were not in the garage when any welding was done. I spent $2500.00 on paint materials for the truck. I'm not going to F it up like that.
  2. Don't get yur comment? But yeah I have awesom insurance and I already had cancer so I think I'll be fine. The garage also has great ventilation.
  3. Ok I'll get a few pics of that when the frame is back from powder. The tubes are just but welded. There are 7 mounting points in the front right there. I think it will be ok. But that could be an idea for the next guy to do it.
  4. There is a plate that runs on the bottom of the rebuilt section tieing in to the un-modified section. There is also a pair of gussets on each side. kinda boxes in the whole section. Checked the A-Arm motion? Really? Yeah they goes uppedy down diddy real niicee! Seriously though, the ball joint motion is the same if not better then the full flight set up. They are decent arms, but they really needed sorting. Again this was supposed to do a easy low complicated build. Not a re engineering project. Hence the modification of the A Arms I already had. The only issue may be getting the bump steer sorted by tweaking stem height to correct the motion of tie rods. Also wanna mention that the heim joints will eventually with extreme angle ball joints once spring comes and the bike is on long travel shocks.
  5. I know everyone doesnt have a Outdoor sand blaster but I do so I blasted it. Did some other welds and a couple gussets. Cut and extended a stock steering stem so it would reach the lower bearing location and be 2" taller Front plastic mounts re attached. All un needed brackets were also removed. Coil mount was moved too as I planned on moving the radiator behind the steering stem but it wasnt really fitting. More pics this weekend. Its in powder coat right now. Please no PM's just reply to the post and I'm not looking to do this to everyones frame:( sry but I don't have tons of time with a full time job. Its low because it will be set up for ice and I'll need some long shocks in the spring.
  6. Re attaching and steering stem mount After looking at it for a while, adding the front bars back on Modding the Full flight arms Mocked up to make shock mounts
  7. So trickedcarbine had to mention this frame mod that another member did and I instantly knew I had to do one. So we went down to Komisar motorsports and got me a doner frame to start cutting up. Sweet deal, $130 for a OEM REPLACEMEMT frame. We looked at the geometry of several frames and tried to think of the easiest way to modify the frame with only the current steel structure provided on the frame. This meant we had to cut the parts off the nose in a way that would allow us to reuse each part, however with different placement for a little bit better geometry. The key aspect of the build was to show that not only is it possible to change the stocker, (that has been done already)but that it can be done with minimal tools, fab skills, and material, wich all adds up to a fairly easy DIY modification. Obviously everyone and their brother would love an outlaw, protrax, or even a frame like evan(358banshee) is building. No tubing benders, notchers, or high dollar tools other then the welder(sorry). But with a decent mig(tig prefered) and a cut off wheel you can do this in a garage. Ill start with the stock pics and go from there. Here is after cutting it apart After cutting the center sections out and grinding a lot! Pieced back together
  8. Thought I would mention Komisar motorsports. A buddy of mine took me out there to get some used parts and it was awesom. This guy has tons of parts for banshees and 450's. A real honest guy that doesnt kill on prices. I have been back a few times to get everything from hardware, tires, a arms, to frames. If your in lower michigan you gotta check this guy out for parts. If yur interested he is on ebay with tons of stuff or 419-410-7163 is his number.
  9. Got one. Thanks
  10. Oops dyno port. My phone is too smart lol. I'd like to do 2 pipes in and one pipe out. Any hoo I guess I'll just try it
  11. Thanks guys. I think I'll try to find a silencer that has a big diameter tube and test it out. Maybe do a back to back test. I'm running some dump port pipes for now.
  12. C'mon anyone
  13. Less crap like an extra silencer on my bike would be the idea and maybe a different sound. 2 pipes into 1 single larger tube silencer.
  14. That sounds nice. East on the hand?
  15. Bought some parts from me. Good guy
  16. Good seller!
  17. That looks like fun. Might have to show up
  18. Looks good. I used some of yur pics and just finished my frame. I'll get a post goin soon
  19. I'm thinking about fabing up a 2 into 1 silencer and wonder if anyone has had any luck with this before. Will it be too restrictive for my ported 4 mill? And are there any larger tube silencers out there? Thanks guys
  20. Looking for a plus 4" axle. Price with shipping to 48328 please
  21. Interested in the new cheng shin set. Can you get me a total with shipping to 48328
  22. How much for the rear shock and what weight was it set up for?
  23. For sure any place around oakland county! Setting mine up
