duneshee2024
Everything posted by duneshee2024
  1. works shocks are for +2 arms
  2. all prices are shiped. I also have a 1987 roller that is in pieces now. I dont want to ship this because of the size and i dont really want to part it out. if you are interested pm me. I live in central michigan if you want to pick it up. i accept paypal on everything. a&s triple port cylinders with pistons,and rings(never used 65mm bore) -$625 stock head milled and o-ringed-$100 34mm pj carbs bored to 35mm and set up for alky with cable-$275 1-5 neutral down override only a few passes on it -$300 welded stock crank -$150 stock cases (no chain break)-$125 +12 lonestar no-link roundhouse swingarm powdercoater black(includes chain slides) -$350 round house carrier-$65 stellar stock width +2 forward light weight J-arms alluminum tie rods powdercoated black with bushings and heim joints -$375 lonestar a-arms +1 forward +2 width powder coated orange(coat is worn on bottom of arms) tie rods joints bushings spindels hubs brakes braided brake line master cylinder asv break handle-$475 works tripple rate shocks-$150 r6 rear shock-$45
  3. 2003 yamaha banshee. dune port motor by r&b racing. v-force 3 reeds, upp intakes, 34mm pj carbs, k&n pod filters, welded crank,billet timing plate, cut head(runs 110 octane fuel)shearer drag pipes, asv levers. brand new chain,vitos lock up clutch and pancake bearing. +6 swingarm(also have a stock one to go with it). motor was done in the spring and has very little time on it. I have 5 gallons of mixed gas that can go with it too. also 10 paddle haulers and ims sand snaked on douglas rims go with it. this is a very good running banshee. located in central mi $2700obo im not good at checking this so is you are interested call me at 989-289-0712
