Antiny
Everything posted by Antiny
  1. Antiny
    Stock Mid Pipe
    Just getting mine together, and noticed the pipes I bought has two right side (passenger side) mid pipes for the stock pipes. Does anyone have a driver's side stock mid pipe they can part with...
  2. I'm assembling my Banshee (first one) and have no reference for how the wiring harness should be routed and the optimum points to attach to frame. My CDI box is in the stock location in rear. If anyone has a photo or diagram would be appreciated. Also could not find the same for the cable routing in front. Got it as a bit of a basketcase, so want to make sure I do it right.
  3. I needed a few odds and ends, and hoped someone here had spares. I need: 1. Lower A arm collar-not sure if this is the right term, the metal sleeve that goes inside the bushings that the bolt passes through. 2. Swingarm dust caps, actually just one. 3. A straight, stock tie rod. I do have Paypal, if you have these please PM me a price.
  4. Thanks for the help bansheerider, much appreciated.
  5. New to Banshees, as my question will probably indicate... I have an early axle carrier, and a later model swingarm, I believe. Are they supposed to be the same? I've seen some stock ones that have two tubes welded on the carrier to put the bolts through, and mine does not have that. It also seems that the width is slightly off., the carrier seems too wide. The way it came when fitted to the old swingarm was with four short bolts, and it seems all the ones I have seen have two long bolts that connect the axle carrier to swingarm. Wondering if I can make this work, because I already had it powdercoated. If anyone can advise if they are interchangeable and I am just assembling it wrong, would be appreciate it.
  6. I used a cheapo air hammer, and it was no help. I'm sure the Snap On is 100 times this import I'm using, but that's all I have access to. I just need to find a way to get enough of a gap between the dust caps and frame to get the blade in there at this point, it's pretty tight.
  7. Mine won't budge, and I've finally admitted it's Sawzall time. One problem I did run into is that although I think the blade is a standard width, there is not enough room between the swingarm and frame to actually get to cutting. Has anyone else ran into this?
  8. Antiny
    Used J arm
    I'm wondering if someone has an old J arm for cheap (can't remember which side, so will buy both if necessary). I can't get it apart from the spindle and will have to do some surgery, the others came off just fine. I also will need a swingarm pivot and sleeve (used) because that won't budge either. If you have one, please PM a price with shipping to 60123. I can use Paypal.
