Alright so I have a 2000 bored .40 over, mikuni flatside 28mm carbs, k&n pod no air box, pro circuit exhaust, I'm using yamalube 2R 32:1 mix, oh and e-brake delete. I have just put it all back together, the bike fires right up but has an idle surge revs up and then down. I adjusted the idle screws it levels out but seems like its idling at a higher rpm then normal. If you so much as tap the throttle it sucks in air and chokes out. If I slowly slowly rev press on the throttle it slightly starts to rev then chokes out but it seems like the motor rpms aren't moving at all. I have cleaned the carbs, the jets and everything. I haven't had the carbs jetted yet, not sure what size to go with yet still researching that, but they have 180 mains in them now. Any other ideas as to what could cause this problem?
