BuffaloBanshee
Everything posted by BuffaloBanshee
  1. Wow AKheathen, you were dead right. Pulled off the cover and there she sat. Appears to be minimal damage. Seems to run fine now! Thanks a ton!!!
  2. Hello guys, new to Banshee HQ. I did a search here to try and get some insight my problem, but found nothing: Bottom end issues. My 05' with the Dyno Port 2into1 pipe machine let loose last night. I had the throttle pinned in a high gear when it started to pop and back fire. The machine rolled to a stop and would not fire back up. When I kick it over I can hear a "skuffing/rubing" noise coming from the bottom end. It almost sounds as if the crank spins a bit after the kick is completed. Good compression still though. I have not split the case yet. So, what should I exspect to incounter once dis-assembled? Any feed back would be great. Thanks guys!
