BuffaloBanshee
    05' Dyno Port 2-1. 01' single 36mm
BuffaloBanshee's Achievements
  1. Wow AKheathen, you were dead right. Pulled off the cover and there she sat. Appears to be minimal damage. Seems to run fine now! Thanks a ton!!!
  2. Hello guys, new to Banshee HQ. I did a search here to try and get some insight my problem, but found nothing: Bottom end issues. My 05' with the Dyno Port 2into1 pipe machine let loose last night. I had the throttle pinned in a high gear when it started to pop and back fire. The machine rolled to a stop and would not fire back up. When I kick it over I can hear a "skuffing/rubing" noise coming from the bottom end. It almost sounds as if the crank spins a bit after the kick is completed. Good compression still though. I have not split the case yet. So, what should I exspect to incounter once dis-assembled? Any feed back would be great. Thanks guys!
