mrdoorguy
Everything posted by mrdoorguy
  1. Ok here's my mods stock stroke stock bore 2 into intake 38mm keihin carb trinity stg 4 head 18 cc domes 108-112 octane gas I run toomey t6 pipes and silencers v3 reeds so I had my jugs drag ported by hjr. Put it all back together and it fired right up. Went through heat cycle etc. Runs great at idle and mid range. When I get it on the band it starts pulling really hard then starts cutting out. I had a 200watt Ricky stator. Changed it back to oem heard they are better. I took the jet out of the bott of the carb it read 188. I went to a 182 and worse. Went to 190 got a little better. Should I keep going bigger. Let me know. Thanks a bunch everyone.
  2. I WANT TO BUY IT FROM YOU. LET ME KNOW HOW TO PURCHASE IT. IT WONT LET ME PM YOU. IT SAYS YOU CAN NOT RECIEVE ANY NEW MESSAGES. SO GIVE ME A CALL. 530-409-5380
  3. mrdoorguy
    04 oem stator
    Need a stock stator and pickup. Any body have a good one laying around
  4. How much for stator is it stock or a Ricky adj?
  5. Hey, do you know if I can remove my Ricky cut the plug off and put it on this one some way or is it super sensitive to connectivity.
  6. Let me know if you can find one and how much. I appreciate it
  7. Cool sounds good. Let me know. What's a plug chop. Where I cut it up. What to look for
  8. HEY EVERYONE, I SENT MY JUGS DOWN TO KEVIN AT HJR. DRAG PORTED EM, PUT MY BIKE BANCK TOGETHER AND ITS CUTTING OUT AT THE TOP OF THE BAND. I CALLED HIM HE SAID TO DO A FEW THINGS. AND SAID MY RICKY 200 WATT ADJ STAOR SUCKED. HE SAID THE BEST ONES ARE OEM. ANYBODY HAVE ONE OR WHERE CAN I GET ONE?
  9. WHAT ARE GOOD PIPES FOR A SEMI-BUILT MOTOR. ie drag port, cool head, dual carbs, v3 reeds?
  10. What is case porting? What does it do for you. And why should i get rid of my pipes if i have drag port done? Whats the best dual carb set up?. i want high quality but i don't dont wanna drop a whole boat load of cash?
  11. WHAT ABOUT THE SINGLE CARB? I WAS TOLD IT GIVES YOU MORE BOTTOM END, BUT I DONT WANT THAT. I HAVE A 38 MM KEHIN NOW. IS TWO 38 MM'S TO MUCH?
  12. I WANNA BUILD THIS BIKE. DO I GET MUCH POWER OUT OF CHANGING MY 22CC DOMES FOR A COOL HEAD?
  13. HEY EVERYONE, SO I HAVE A 2004 BANSHEE. STOCK CYLINDERS, 2INTO1 INTAKE WITH 38MM KEHIN CARB. NO PORTING, TOOMEY T-6 PIPES,V FORCE 3 REEDS,NEW TOOMEY CLUTCH, TRAIL TECH HEADLIGHTS, AND ALL KINDS OF OTHER GOOD STUFF; BUT NEED MORE HP. I HAVE BEEN A 4STROKE GUY ALL MY LIFE, BUT LOVE 2 STROKE PULL. THIS IS A SAND MTN (NEVADA) BIKE. I DON'T WANT A FULL DRAG BIKE BUT I WANT 99% TOP END. I TALKED TO KEVIN AT HERR JUGS, THINK IM GETTING GET DRAG PORT. SHOULD I GET A COOL HEAD? HOW DO INSTALL IT. HOOK ME UP GUYS. THANKS CHRIS
  14. HEY GUYS, SINCE WERE TALKING ABOUT TRINITY PORTIN AND ALL, I CALLED TRINITY AND TALKED TO SOME GUY, HE WANTED AN OUTRAGEOUS AMOUNT OF MONEY TO SET ME UP WITH A DRAG STYLE PORT. SO I CALLED AROUND LOOKED UP SOME INFO AND GOT AHOLD OF KEVIN AT HERR JUGS. EXTREMELY KNOWLEDGE ABLE, MY ONLY QUESTION IS SHOULD I PULL MY HEADS OFF MYSELF, SHIP THEM DOWN THERE, OR SHOULD I HAVE HIM TO DO IT. WHAT NEEDS TO BE DONE TO ENSURE MAX HP OUTPUT AFTER PROTING IS DONE? DO I JUST BOLT THEM ON OR DO I NEED TO REJET, ADJUST TIMING OR WHAT. THANKS
