i ordered a used oem stator and pick up coil from ebay. hopefully that will come in this week so i can hit the trails.
i have another question that i cant seem to find an answer to....i have a +4degree key, when i took off my flywheel yesterday, the key was kind of loose so i popped it out. my question is, how do i put it back in or should i put in a stock key. i have an adjustable timing plate i found out, so i dont know why you would put a degree key in it. after reading a few threads on here it sounds like i should put a stock key in it and just use the timing plate. is there some kind of adhesive to keep the key in? do i put the stock key in flush with the contour of the shaft or level with the ground like i read you do with the degree key. is there someone you guys recommend i order the stock key from?
