cellboothmgr
cellboothmgr's Achievements
  1. i ordered a used oem stator and pick up coil from ebay. hopefully that will come in this week so i can hit the trails. i have another question that i cant seem to find an answer to....i have a +4degree key, when i took off my flywheel yesterday, the key was kind of loose so i popped it out. my question is, how do i put it back in or should i put in a stock key. i have an adjustable timing plate i found out, so i dont know why you would put a degree key in it. after reading a few threads on here it sounds like i should put a stock key in it and just use the timing plate. is there some kind of adhesive to keep the key in? do i put the stock key in flush with the contour of the shaft or level with the ground like i read you do with the degree key. is there someone you guys recommend i order the stock key from?
  2. so i talked to the kid i bought the banshee off of, and of course the stator he put in is an RM Stator. they have a 1 year warranty so im going to try to get it replaced through them.
  3. awesome, again thanks for the help.....on a side note, when i was taking the cover off the stator and everything, i happened to notice i have 2 wires from the thumb throttle, black/yellow and black(i think) that were cut and just hanging there. i havent had time to look on here to see what they are or if they need to be connected somewhere yet.
  4. thanks for the input. im planning on buying this: http://cgi.ebay.com/ebaymotors/87-1994-Yamaha-Banshee-Stator-ADJUSTABLE-TIMING-PLATE-_W0QQcmdZViewItemQQhashZitem43a1579196QQitemZ290469679510QQptZMotorsQ5fATVQ5fPartsQ5fAccessories#ht_1448wt_1043 the guy said i can send back the bad coil and pay the difference for the stator and adjustable timing plate. does that look like what im going to need to fix my problem? i want to make sure i do it right the first time so i dont have to spend all kinds of money and time on it... is there anyway i can tear it apart and just clean it up a little bit? or do i need to completely replace it with the stuff in the link. thanks guys
  5. update: i disconnected the TORS box under the front left. i checked with the manual i downloaded. from my readings i took, it says the stator and stator assembly and the ignition coil need replaced. the guy i bought the coil off of is sending me a replacement since it doesnt test out. should i replace the stator and the stator assembly or is there an easier fix?
  6. hello everyone. im new here so please dont hammer me for asking what might be a simple question. i tried searching but couldnt really find an answer. i bought my banshee knowing there was no spark. the guy said it just needed a new ignition coil. i bought one on ebay and when i do the secondary test, i get infinite or no reading. i took the caps off and tested the - and wire and still get nothing. i tested the old coil and it gave me the same results. the first test both checked out at .4ohms here is what the bike has vitos +4 degree key new stator stage 2 cdi box fmf exhaust cool head so i tested the stator hitting the green and red wires and they show 11.4 ohms. the giant post on this site says it should be 13-20ish. is 11.4 mean i have a bad stator? when i hit the other 2 wires on the stator wiring harness, green/white and red/white(?), they showed nothing. i think that is testing the pick up coil? i read that the pick up coil has to be set to a certain spec. would that cause the bike to have no spark? since the pick up coil tested with 0 i stopped testing wires because i am assuming thats my problem. any help would be awesome. thanks
