lawngod
Everything posted by lawngod
  1. i have a got a set of cases why is it the best to keep them together.i have split the case on 2 or 3 blasters
  2. just to replace the cracked case
  3. i have a new full gasket kit
  4. yes that is it ... im a ex B.C boy (Abbotsford )
  5. what about the cluch and the bearing plate ? I just got it 8 week ago and it has bin a lot of sleepless nights. they did a half ass tors removel . they tryed to fix a crack in the bottem end with some kind of metal .welded the foot pegs on.
  6. i have read all the talk about this job . Some guys say i can do it by just taking off the lower half. but about the cluch and the bearing plate. can you guys please give me a step bye step to do this. thanks for all the help , iam happ y to see all the shee freaks out there.
  7. do you have to take off the cluch and the bearing stop plate
  8. i did the compression test and 110-115 . This is just crapy. i have to ride my lt230 and that sucks.Its in the carbs
  9. Having a bad week .You guys know what i mean
  10. i have a tester . What is the best way to do so . plus it seems to run good cold .
  11. left carb not working . If i take out the brass screw and nut it will fire with alot of white smoke. If i screw in or out the brass screws with nut it does f-all. Oil coming from left can . i have cleaned filter and the carbs. new plugs i just go the bike 3 weeks ago . I have had a blaster and i am up to speed on 2 strokes. i think its the tors sys and its has bin taken out .
  12. thanks will look tonight just got bike . 32-1 . I just cleaned filter and carbs . I will go back in and look.
  13. they are all good .
  14. good day lads i need some help . 00 shee fmf ,tors out . i just got this shee and having a problem left side plug foweling. I have had 3 blasters and never had this happen.
