bansheeboi
Everything posted by bansheeboi
  1. Guys I rejetted my shee and now the left smokes an the right won't, the left side gets hot right side don't. I've tired swaping wire to see if problem stop an it dosent help wht next?
  2. If you part out I would like the rear paddle no rims
  3. finally got my jets on the way
  4. paint them yourself it's really not hard at all
  5. What will make it look better? But still have the sleeper look?
  6. now its boggs like hell then clears up an ripes but sometime it will start with or without the choke
  7. Okay got the tube hooked on both carbs half turn out now its bogging like its straving for air then bout half throttle it clear up an rips
  8. Ok cool I'm looking for pilots 27.5 an maybe 290 main, thanks
  9. hay infamous didnt you tell me you had a load of stock jets if so i'm in need of some let me know bro
  10. My ole lady banshee has t5's cascade silencer no air box uni pod stock reed, stock carbs? So my question is what jetting is good for her bike currently has 300 mains stock pilot air screw 1/2 turn out. The bike idle then dies if I dont tap gas idle screw installed screwed all the way in im at sea level 80-90 degree weather help this bike is driving me nuts on getting it to run perfect. Also my shee has 34pjs 160 main and 50 pilot still a lil rich. You guys think I should drop to a 158 main and 48 pilot not sure on the needle setting on either bikes.
  11. ive got rocket pipes an they ripe hard you will like them a lot just dont buy the black ones
  12. Choke is off, but I've tired it with choke on not to much of a diffence
  13. guys when i start my she it has a very high idle for bout a min or better then it idle down to normal idle. Any help on what could be the problem? It only does it the very first start or the day. carbs are 34pjs 160mains 50pilot
  14. I've got 300 mains and how do move the clip? I've got is running better but its got a lil bog, also a lag before the powerband.
  15. The is the setup t5's cascade silencer stock carbs 300 mains not sure on pilots uni pod filter. Okay bike will only run idle when choke is pulled out, I push choke in an bike act like its leaning out and shuts off. Also if choke is push in bike will not start. What do I need to do guys to get this thing to idle its me ole lady bike an she ready to ride, and race.
  16. The is the setup t5's cascade silencer stock carbs 300 mains not sure on pilots uni pod filter. Okay bike will only run idle when choke is pulled out, I push choke in an bike act like its leaning out and shuts off. Also if choke is push in bike will not start. What do I need to do guys to get this thing to idle its me ole lady bike an she ready to ride, and race.
  17. Also have some itp fronts 10" on dune streakers these pics are old those wheels have been polished since I took pic. There also a set of itp rear wheel the rims are an 8" wheel on tires also, I looking for coil and stator an some jets for my stock carbs, and 34 pjs let me know.
  18. No piston melt down I crank the bike again before I pulled carbs off lastnight. But I did notice that it will idle nicely with the choke pulled out an push back in it idles a lil higher.
  19. Yes I did plus the other carbs had the idler screw installed also other carbs didn't.
  20. Yes I hd the carbs laying around gave them a good cleaning an wanted to try them out.
  21. Not sure I'm going to pull the carbs back off an I let you know thanks
  22. Okay guys, I changed the carbs on my other banshee and crank it up. The bike idle good then it idle really high, so I shut the bike down and tried again. So she idle fine again tap the gas nice no problem there. Okay now I. I went round the corner first,second,third gear she died guys throw ideas for me to check. Also the setup on this bike is t5s cascade,uni pod stock carbs. I only change the carbs because those carbs was jetted for the t5s that came with my other bike.
  23. bansheeboi
    parts
    Looking for a cdi box round plug ,coil, and maybe a stator let me price an send pics please thanks
  24. bro do you have a rear shock laying around? we can work out something for those tires and that handle bars if its not sold let me know thanks bro
  25. Guys mybad whats the dates for the ride again? I've been very busy at work and really just getting back around to riding me shee. I've got a crew that wanna do something it will be very nice for some georgia boys to come out an play please keep me informed thanks.
