my mods are as listed
FMF gold series sst
powercore 2 siliencers
Bossien pro series reeds
boost bottle
k&n with lid on and snorkel off
Jetting Spec's
220 main
27.5 pilot
stock needle third notch
air screw 2 turns
elevation 2100ft /temp 60-80 f
Recently I had 200 mains/stock pilots/ third notch clip/ 2 turns out on airscrew - I was running just the pipes with the airbox lid and snorkel on. none off the other mods were added, and the bike was running good but obvisiuosly lacking due to the airbox lid on. The plugs were looking nice at this time.
When I added the reeds, boost bottle, and k&n and removed the snorkel, then this is the sequence of the jetting that worked best- 220main,27.5pilot and 2 turns on the air screw with the stock needle remainin the same third notch
The bike seemed to run very good, but I'm a little lean.
response right at idle will bog if you pin it imeddiately, but if you just rev it up a bit first before crackin her hard its excellent
response off low idle while riding is excellent
respones on mid at low idle is a little bit boggish, but if your up in the rpms in mid its very good.
WOT response is good but I am concerned I am to lean
The plugs look chocolate brown on the electrode and slightly colored on the based.
My question is no doubt that I should richen it a bit....seems like it would be good to start in the mid to see if that helps. Every time I tryed to go richer in the mid by clip setting it never works. I do have different needles from a dyno jet stage two kit will these work with mikunni jets or are they made only for dyno jets? I was also thinking about upping the pilot one to a 30. Since I noticed the best results from changing the stock pilot to the 27.5?
What do you guys think? Carb since is excellent I forgot to mention. I appreciate any helpfull answers.
and yes I do need to try a plug chop but am wanting to do that when I am closer to being dailed in.
I
