bigboy
Everything posted by bigboy
  1. bigboy
    Fuel Pump?
    Ok thx guys.
  2. bigboy
    Fuel Pump?
    I have a 611 DM . Should i use a fuel pump? 44MM alky.
  3. Appreciate the help.Thx
  4. DM guys out there. What oil mix ratio to Alcohol?
  5. Ok. Thanks for all the help guys. I really do appreciate it.
  6. I'm running 44 lectrons carbs on my 14 mil. Should i run a fuel pump? Thx
  7. Alabama
  8. I cant get them to load on here shoot me a email address and ill send them to you guys.
  9. Ok And?
  10. I have a newly built(9/12/2014) 611 DM for sale. I stored the bike in 10/18/2014).It is a monster and only has a few passes on engine. This engine was built by Tim Bond at Titan Racing. This engine has everything. This is a very quality built engine. I have tons invested in this motor. Who ever gets this engine will have a a great engine. There is way too much in the engine to list but i will attempt to list anyway. 1.Hinson Complete Billet Proof Clutch kit w/ Straight cut gears(8 plate) 2. Aftermarket stator and clutch covers 3. Billet 10 mill Crank by crankworks 4. 1-5 override neutral Down 5. 44mm Lectron Carbs 6. Vforce 3 reeds 7. Billet intakes 8.Shearer Big Bore(Big Flange pipes) 9.Custom Cut Domes 10. Lockout 11. Custom Case Work 12. Billet Kick Starter 13. Billet Shifter 13.+10 Cascade innovation Swingarm 14. Alley Cat chassis from Terry at Deafman 15. American Racer Tires SD23 Compound 16. Direct Drive 10 x 2 rims 17. Aluminium fuel tank 18. Aluminium Radiator 19.PBI Sprockets 20. Custom Rear Brake Rotor 21.Billet Grips 22. JJ&A Drag Axle(Lifetime Warranty) 23. Round style carrier(Black) ALCOHOL MOTOR!!!!!!! $9000.00
  11. I was just wonder the ball park figure on getting a 611 DM built?
  12. Thanks for your help.
  13. How much should case work cost me for a 611 DM(trenching, case boring, and welding up cases)?
  14. Thanks for all the help guys.
  15. OK thx
  16. Can anyone guide me in the right direction for buying drag pipes for my 611 DM I'm building?
  17. Thanks for the info.
  18. Can anyone tell me the part number for v force 3 reed for a 611 DM(CR500)?
  19. Should I buy Lectron 44mm or 48mm alky carbs for my 611DM?
