hondamxerd
Everything posted by hondamxerd
  1. the track is 4/10 mile oval clay...thanks for the good info about what compound, where do you buy ur rims or the cheapest place... and what about some of those lowering kits on ebay, that claim to lower and widen the front, are they any good, or should i save up for some ff arms or some r6 shocks and wheel spacers... kinda on a budget( who isnt?..lol) thanks again...
  2. can someone plz explain what exactly is tors and the purpose? also is it better removed, can i simply unplug to run a twist throttle? thanks
  3. these look very good, they are really big tho, will they fit with no clearance prob? also ima have to buy rims too, its just gonna be oval track, no jumps, do i really need beadlocks or can i get away with blue labels? one more, ive seen the dura tires on ebay, are they ok or is the hoosier better, the track is actually a car track but they are gonna runs quads a few times too...thanks again
  4. the old needles were factory out of an 06 and they have some writing on them but i cant determine what it says... the new ones are a kit off ebay, non brand specific... but i just went out n tried it out , i also went up to a 290 main, that was the purpose of buying this kit, but it came with new needles, n turned out i needed them, but neways put it on the 3 clip setting and it bogs a lil at bottom n mid, put powerband is way better now doesnt flatten out... so that means up a clip setting? thanks for your help
  5. ok no cut, so these will work... right? and if so stay with the 3 clip setting for starters or what, thanks..
  6. i just bought a jet kit off of ebay and it came with new needles, i was goin to use them since one of mine is bent, but they are longer and i cant adust for the added length with the c clip, anyone know y they would be longer and is there any way to cut them down to size?
  7. hondamxerd
    tires
    where is the best place to buy some dirt track tires, cheapest place...lol.. i also need some wheels.. thanks.
  8. lmao..... i really screwed up, but i did find out what can get gunk off... i tried oven cleaner, if you just put it on for an hour or so it does ok, so i decided to leave it on overnight.... DO NOT DO THIS.... it ruined the polish on all my aluminum, where the paint was thin or chipped the paint around it came off... so now i was wondering how much i would be looking at to powder coat the frame... thanks...
  9. no, how do you do that..lol
  10. they are leaking from the drain tubes on the carbs, and i thought floats but i cleaned them and still leaking... is there an adjustment on them?
  11. 06 banshee fmf titaniums with gold seiries pipes, k&n filter, and timing plate, stock everything else. 280 main jets, feels a lil flat on top, should i try a 290, also the carbs are leaking fuel when setting still not running, i took them apart and cleaned well but still leaking any suggestions thanks
  12. i traded for an 06 banshee, its overall not in bad shape, but, it is filthy.... I have pressure washed it and tried purple power, but it has gunk grease caked on it. around the a arms swingarm and on the engine, it had some seal leaks apparently for a while, i have fixed these but im trying to clean it up to sell it, any ideas on an easy way to get this stuff off? thanks
  13. what year r6 shock, i found a 2010 and its a lil diff from previous years
