GrayRacing
Everything posted by GrayRacing
  1. no, the motor doesnt get hot. maybe by the end of the night of racing, it gets just a little warm but u can still lay your hand on those cylinders. i would build brackets but how my steering stem is set up, i would actually have to make the stem longer to drop the radiator
  2. yea, i drag race. mostly 200ft, and sometimes 300ft. its on alky, but that motor does get hot. i was thinking of throwing a dirtbike radiator on it. ill have pics of my bike after i get the motor back from kim.
  3. k&t done mine, but i have no passes on it yet. whatever you do, dont call rdz. we called and they act like they didnt want our business. they said they stopped working on cubs, only dmxs. but whatever floats their boat.
  4. GrayRacing
    Pipe?
    those might be cheap but if your wanting to get power out of your pipes, go to a set of shearer sb. thats what i have. power pros, a good pipe but its something you would maybe wanna put on a stock cylinder bike, not a cub
  5. why wont freaking summer just hurry the frig up !?
  6. ok, i bought a fiberglass hood and i was wondering if it was ok to leave the radiator in the place where it comes factory or do i need to build brackets to lower the radiator. i dont want it to over heat from lack of air and burn up. im just very curious and its been aggravating me.
  7. GrayRacing
    Shearer BB
    race season is around the cornor and im looking for a nice set of OOF shearer bigbores. id perfer them both coming out the same side. if anyone has a set, u can text me at 1-606-627-9836 or just pm me.
  8. im gonna use a wet system, and my bike is running off alky and everyone tells me to use gas as a additive. and idk about the ignition. i have 180 pounds of compression in each cylinder
  9. GrayRacing
    Nitrous
    ok guys, my cub cylinders are being sent off to millennium to be renikiled. my bike ran constitant 3.1s and 3.2s in 200ft. im wanting to stick a 25-35 shot of nitrous to it set a track record, whats the biggest shot of spray you can stick to a motor like that and how many tenths should it pick you up ? im just needing to know before i go too big on the spray and blow it all to heck.
  10. port the heck out of the exhaust and throw the alky to those stock carbs. ive seen a completely stock bike at stanford run 3.8s in 200ft just like that.
  11. ok guys. this is what happened. i raced last week, my bike was alright. later in the night, i went to purge my bike, it wouldnt kick over. took my motor apart at the house,and a clip off the wristpin came off and scratched my right side cylinder up and piston. would anyone know how this could happen and anyone got any recommendations where to get them renikasiled ?
  12. im running vf2 reeds, vf3 sucks balls. i have 37.5 pwks, cpi smallbores, lonestar drag axle, lonestar swinger. im using studded realtors with 72 icepicks in each tire, running 6 pounds of air in them, but my bike is what it should be running now.
  13. GrayRacing
    Nitrous Kit
    looking for a nitrous kit, wet only. im looking to put a 20-30 shot to my cub to pick some speed up. pm me or text 1-606-627-9836 send pix
  14. ok, i was in the 3.2s with my setup. i should be in 3.1s in 200ft this week at the new track in harlan, im doing a little more work on my ice pick realtors, lean out my carbs a little, and im using a set of sb cpi stinger pipes.
  15. i have a friend named tom isom, he has a drag bike with a extended frame, 4mil k&t stock cylinder bike with pwk carbs, and cut tranny for around 2800
  16. hey guys, im just wanting to get rid of this smoked glass and im wanting to know that if they do make a purple or light green lexan glass. if so, can someone tell me the website ? thanks if you do.
  17. give kim at K&T a call.
  18. u know that im definitly interesterd.
  19. finally got my bike in the low 3.2s tonight, close to 3.1s, and im running outta fuel too aswell, i need a set of billet bowls, anyone got any for sale ?
  20. thats what you think but i was at full throttle one night, i had 9s in as usual, and it was prolly 75 degrees outside, i couldnt get the alky to burn then i went to a 8, it was a little better then i went to a 7. its like my bike wouldnt run warm.
  21. my bud has a set of bills on his yellow banshee. they are way better than fatties. i have sst's on my bike, and it sounds pretty good.
  22. i run consistant 3.17s in 200ft from tuning my carbs, for 1, i would go to a set of 38-39mm airstrykers, go to a size 52 on your pilot jet, and drill ur main jet out. set your timing to +7 degrees, and what i did on my 1st race was that i raised my needles all the way up, and if it was too fat, then id drop them, i kept dropping them until i got it lean but yet fat. and i usually run ngk spark plugs, i use a BR9ES, and if its not hot enough, go to a BR7ES.
  23. whats your email address ? ill send a pic of mine.
  24. alrighty.
