bansheeonfire
Everything posted by bansheeonfire
  1. Well here we go again. The quad was running perfect and my son got it out for his first spring ride and the same thing. Starts then stalls. Was running great when we fixed it last time.
  2. Well my bad on this one. We checked all electrics and everything seemed fine. Lots of spark. We re-checked the carb sync and it was out by 1/16. Readjusted the throttle cable and it fired right up and purred like a kitten. My son rode it for 20 mins said it ran great. The one throttle cable was not seated in the adjuster on the cap all the way in. Lesson learned.
  3. Yes it is running rich. When it did start if you touched the throttle it bogged out.
  4. Off on switches and key? It has fullbore fenders on it. Ignition key is jerryrigged out the right side of the rad. Had to pull the old throttle cable past it to remove it. Good thought. I will check that the Ignition wires were not loosened when i pulled the old throttle cable through. Thanks.
  5. Yes it has the tors delete idle screws on each carb. I did not move them. I adjusted the carb sync by using the adjusting nuts on the carb caps. I cant see how turning the idle screws in will help. Its getting too much fuel as it is. I did not remove the carbs or touch anything else other than removing the carb caps to get the old cables out of the slides. I myself suspect an electrical issue. When i cut the wire ties off the main wiring harness maybe i disturbed a wire. We are going over it this upcoming monday and re-checking everything. It has to be something simple.
  6. Also my friend who is a banshee expert who owns 12, yes 12 banshees says the plugs are fouled. I put in two new plugs wont start at all now.
  7. No. Touched non of that. And tube between carbs is intact. Also i did not put the left carb slide in the right side carb.
  8. Also compression is good and plugs are very wet. Checked spark. Lots.
  9. Hi my son has a 2001 banshee with a twist throttle. I bought him a thumb throttle and replaced it with the twist throttle last week. The twist throttle cable was longer but i had a spare motion pro cable which i installed. Yes his banshee has the tors delete kit on it. I syncronised the carbs and now it fires up first kick and then just dies. Ran perfect before we put the thumb throttle on. Any ideas?
  10. well actually I was expecting more power!! sure the fmfs are good pipes but there are way better other pipes on the market. obviously I need to rejet richer so that's where ill start. and seriously I don't know why theres so many dynoport haters out there!!
  11. I just bought a used dynoport pipe for my 01 banshee and it falls flat in the mid/top end. I was using fmf pipes which worked good but I have always wanted to try a dynoport and I got the complete system for 120 bucks. any banshee owners out there with this pipe that can tell me how to jet for this pipe? I will assume it needs richer jetting ?
  12. yeah nice, hq general, so are you saying they wont work?? the ad did not show the different reed, btw I paid .17 bucks for them and the seller will refund me or give me a 50 percent discount By my calculations that's 8.50 for the set not a huge loss!! reed blocks are perfect and so are the reeds even though one is different. I have ran banshees for 25 years and I am 48 years old . was just asking an honest question Personally I think you Americanos have way too much my shit don't stink attitude, We are not all dumbfuck rednecks out here!!
  13. I bought a stock set of banshee reed blocks with boyesen reeds from ebay and when I got them 3 reeds are single stage reeds and 1 reed is a dual stage reed..does anyone know if these will work properly??? also the reed stoppers are still on wtf???
  14. I need this clutch cable, is it still available?
  15. brake stay still available??
  16. I have a stock banshee cyl head, stock front plastic grill, new coolant relocation bracket, left front spindle and stock carb cables and caps, I need a k&n filter, boyesen or similar aftermarket reeds and a braided rear brake line, thanks
  17. how old are these pipes? I think this is a great deal as long as theres no cracks or dents, I am interested, how much to ship to Sutton Ontario Canada l0e 1r0 usps only
  18. yes I did try putting the coil on the upper side of the mounts but then the plug wires didn't reach and I did not want to buy a splice set and more spark plug wire. seems like a lot of shit you have to do to get these to work but im going to strip it down again hopefully this weekend and start over. I just got frustrated on my first try because as I said there is a lot of tweaking to do as opposed to the fmf pipes I have on my banshee .but the replies I got from all of you solid guys inspires me, I will post back when I am finished. btw one more question, I have 260 main jets in my banshee, would this be a good size to start off with on my girlfriends banshee? it is bone stock other than a Toomey foam air filter,
  19. thank you all very much for your help, greatly appreciated!! I will try again,
  20. holy shit!!! you guys rock, 10 minutes and a reply, on bluetraxx 3 days no reply, I know where im staying, seriously though I would have to be a complete idiot to have these on the wrong sides, I had them on right as per your pic. but what about the coil? is that dent in the right pipe there from the factory to butt up against the coil??
  21. I recently purchased a used set of paul turner high rev pipes for my wifes 2006 banshee. first of all there is a stamp that says 99 banshee on the plate, cant see how that matters since they are all the same 87-06. anyways there are 3 problems, first, the right pipe butts up against the coil, second the pipes touch both the coolant pipes and third, the left end of the pipe butts up against the fuel petcock, allowing me to only run on reserve!!!! anyone had the same problem??
