rudy2191
Everything posted by rudy2191
  1. hi everyone i have a little issue with my banshee,at times its hard to start, like i pull the choke out and kik and kik and it wont start but at other times it will start at the second kick, although i did notice this only sometimes happens when the bike is cold, everything is stock, it just has the tors remover kit. sometimes i spray starting fluid and it will turn on the second kick once its running, it turns on the first kick. any help will be appreciated my air screw is about 1 3/4 out temperature in is about 60* to 80* degrees
  2. pretty funny, lol yea i cleaned out the carb good, the jets are fine it wasnt dirty a bit, and i went ahead and bought new spark plugs already, although i just notice that my idle screw from the left carb is missing, i removed the tors already and purcahsed a kit, and the idle screw is gone, it idles okay, but can that be the problem?? , regardless i already order a new set of idle screws, because i still need it and also when i rev it, smoke does come out, sometimes even sometimes less than the right thanks for the help
  3. hi everyone, i have a little problem with my banshee it was runing fine until yesterday that i notice the smoke comes out more from the right side exhaust, pretty much its not even, at times you cant see smoke coming out from the left side, i put my hand at the end of exhaust and it seems like the right one has more pressue than the left, just wondering what it was, both pistons have ggod compression can it be a spark plug,? thankyou
  4. does anyone know where i can get the whole kit bearing inside the cases, like the crank and stuff thanxs
  5. yea, thanxs everyone for the help, but i finally go it, its the output shaft bearing, when i move it with my hand, it makes the noise and it gets stuck at times thanks everyone
  6. ohh i see, well i rode the bike around gently, and the gears dont pop or anything, and i rev up the engine and it doesnt sound, it basically sounds as i start to drive it, like when its rolling it does the noise, whether if its on or off it does this noise. well thats great that you resolved your issue, although my clutch seems to be okay there is no wear to it thankxs
  7. i checked the oil and it doesnt have any shaving, the oil level was good in it, at idle it turns on great, when i shift to first and release the clutch,( as the bikes rolls) it makes a screaching noise, it sounds like if metal and metal are touching or so, even when it off and in neutral when i roll it, it does that noise. yea chain is oiled, chain has free play its ok, to me it sounds like the clutch bearings are gone bad but not quite sure, but this symptons go on , whether its on or off.
  8. hello everyone, i have a problem and i hope you guys can give me ideas how to solve it. i bought a banshee about 3 months ago and it ran fine. i went riding about a week ago, and a buddy of mine was using it,( i dk why i let him borrow it) and it was running fine until we heard a noise on the engine. it sounds like something scratching so we turned it off, and i fired it up again and it fires up although when i put it in gear and let go of the clutch it starts making a loud scratching noise. so we left it alone, i thought maybe it was the clutch, so today i started taking it apart, alothough when i have it on neutral and i push it, it makes that scratching noise at times it will go away then come back. so i took a look in the clutch and it seems to be okay. im killing myself here, maybe i am wrong it is the clutch or a bearing inside the engine any help would be great thankyou very much
