BANSHEEAHOLIC
1 Follower
About BANSHEEAHOLIC
  • Birthday 12/28/1982
    Philly
Contact Methods
    95' Banshee
BANSHEEAHOLIC's Achievements
  1. I have a used set of FMF Fatty pipes and wanna trade for a set of PTR Mids! My pipes are in ok condition with one small dent! They will need some cleaning up! Any condition PTR's is ok for the simply fact I'm getting them powercoated anyway! You can post or send pics and price to [email protected]
  2. I'm looking for the Shark (jaws) front bumper, A good set of tires I perfer holeshots, maxxis razor 2, or turf tamers. My rims are stock! I need a key shut off box with key, Black, red or yellow handlebars. Please post or send me pics and price to [email protected]. thanx
  3. What are your prices? Do you have a set price list?
  4. Ok I go into the garage to check on this black box y'all mentioned. 1 I didn't see any box (maybe I looked in the wrong spot) The only thing I saw was the box for the spark plug wires. 2 I kicked twice and she fired up out of nowhere I keep gasing her for about 2 minutes ( white smoke was coming out pretty thick) I tried to get her to idle but she cut right off, I kicked and one kick she back on! She died out again but this time I kicked more then David akers in the NFL LOL and she didn't do anything! Any more Ideas? Also I believe the compression is good cause when I kick I feel the kick shifter kick back!
  5. First, Thanx 87sheerips. I will go through the checks! Now I'm new to the Shee troubleshooting, What is the Tors?
  6. Thanx again john for the parts! Definitely a pleasure to meet you! I will be back up to check you out again!
  7. I just discovered that I have a +2 swingarm. So I need a +2 or longer brake line instead of the stock one I posted for before!
  8. Never had an issue with starting but now shee is misbehaving! Only thing I have done is changed the oil and spark plugs (NGK B8es), and a good old fashion wipe down! Now I go to take her out for a spin after work and she won't turn over. I have pulled the choked and still nothing! I kicked for over an hour! Sometimes she acts like she is going to fire up but she don't! After pulling the spark plugs they are wet with gas! I don't understand why there is so much gas in the cylinders! Any Ideas fella's?
  9. I'm in desperate need of the entire rear brake system from foot peg to rotor and all mounting screws!!!!!! I also need the bracket that holds down the clutch cable to the engine block. How much shipped to 19139 philadelphia? Thanx
  10. I need the Clutch cable mounting bracket and screw. Its the bracket that screws down into the engine block and holds the cable secure. I also need the entire rear brake assembly from foot peg to rotor! The entire setup please including all mounting bolts too! I also need a aftermarket handlebars ( perfer red or yellow), black, red, or yellow plastics UNCUT!!!!!!, front razor maxxis tires, aftermarket front bumper (perfer jaws bumper), red or yellow headlight covers. I may need more I will update after I do another walk around... PAYPAL LOCKED AND LOADED
  11. I need the Clutch cable mounting bracket and screw. Its the bracket that screws down into the engine block and holds the cable secure. I also need the entire rear brake assembly from foot peg to rotor! The entire setup please including all mounting bolts too! I also need a aftermarket handlebars ( perfer red or yellow), black, red, or yellow plastics UNCUT!!!!!!, front razor maxxis tires, aftermarket front bumper (perfer jaws bumper), red or yellow headlight covers. I may need more I will update after I do another walk around... PAYPAL LOCKED AND LOADED
  12. Do you have the clutch cable mounting bracket that holdsdown the clutch cable to the engine block? Also I need the mounting bolts to mount the rear caliper to the rotor!
