Walms...This is why many people switch or stop using forums. Some folks tend to get Computer Balls since they have the ability to be anonymous. I like many in here are not experts but have learned a lot from the more emotionally stable guys in here.. I wasn't aware that a slight adjustment to your throttle cable on a PJ was a cardinal sin. From what you described it seems like you have a decent understanding of lean & rich & how the circuits work with each other. Ask yourself a few questions. If you have a certain pilot & have your choke opened up too much and you supposedly have a good idle, why would you lean out your pilot when you obviously were having to make up for a lean pilot by richening your choke adjust? If your choke is open too much and it's running good then you would put a larger pilot, enabling you to close your choke adjust & maintain the same air/fuel mix. If the needle is the primary circuit for midrange, then why change the pilot for a midrange issue? If a "normal" carb has a mechanical idle adjust (screw)...isn't adjusting your idle merely pushing your slide up? Why would a slight pull on your slide from the other end be a substantial no no? Also, if you synch a PJ by adjusting the throttle cable at the cap, why would adjusting the other end "slightly" be a substantial problem? Also, when tuning your idle circuit you use the air screw to gauge your pilot size...not the other way around. You open your air screw until you reach max idle. I then back mine off 1/8 turn. If it is open more than 1.5-2 turns than put a smaller pilot. If open less than 1 turn than try larger pilot. It shouldn't take you too long too find step by step jetting instructions in here to verify this process. You shouldn't just keep throwing jets/$$$ at it when your air screw will tell you exactly what you need. I do agree that if your choke/idle is opened too much then you need a different pilot (larger) & I do agree that your throttle cable shouldn't be your primary idle adjustment. I'm sure there are some actual gurus in here that may agree with "mr happy" about adjusting your cable. I definately think you need to do a proper tune 1st. Without knowing any Kawasaki oem mods to your PJ's, other mods & elevation and temp...the best anybody can do is give general advice and tips. Being as a 35 pilot is as small as you can go...unless you are running at 6000' + elevation & 90+ degs, it's probably too small to begin with. If at sea-1000' & 70deg you should probably be around stock, probably 1 size smaller & go from there. Higher elevations/warmer climates = smaller jets to match your thinner air & lower elevations/cooler climates = larger jets to match the more dense air. It's hard to tell from this side of the computer but it sounds like you may need to start closer to stock & tune with airscrew from there. Stock PJ specs are 152main / 55pilot / CEGneedle & 16mm float height. Your pilot & needle are substantially leaner than this but I have know idea if Kawasaki modified these for your bike. 1 last thing, if your 34mm PJs were not the stock size carbs then you'll have a hell of a time adjusting them enough to get an idle. Don't trust everything others say or me either since some rocket scientist called me a "tool". There's enough advise on here to prove things out & make sure it makes sense before you do it.
