Dubz03
Dubz03's Achievements
  1. It ended up being that i forgot to disconnect the harness going to the throtle. Thank you for the help!!!
  2. I am having the same problem that michaud321 is having. I tried what AKheathen said to do by diconnecting the little black box and disconnected the e-brake switch and it is still running the same, it will only idle and if you try to rev it it sounds like it's sucking in to much air and bogs.
  3. I'am hoping that some one can help me with my engine, it will only idle and as soon as i hit the throttle it starts bogging and makes a sucking noise from the carbs. I have cleaned both carbs and it still runs the same. I'm new to the banshee and looking to see my next step should be to fix this thing.
