2003 black drag cut front plastic airbrushed up cut seat vitos 68mm big block cylinders lol. Alot of reworking full tripple port and pollished,38mm keihn carbs on methanol, big bossracing bowls and intake v force reeds,
rickystator timing plate, lockup clutch, pingel dual feed petcock, 4mm crank, 1-4 overide 5th and 6th manual, out frame same side exit pipes from wms, dynatek fs ignition, plus 12 swinger american racing wheels and tires all way round just a simple small motor set up that gets down
Recent Profile Visitors
The bike has a vitos hemi head 18 cc domes on stock cylinders ported pretty agressive 4mill v force reeds boss one piece intake 35mm keihns sittin on big boss bowls alky
The main jet is a 113 not shure on the pilot we bumped it up to a 116 main and put a set of 19 cc domes in not exactly shure on what the mechanic cut them to
dropped the compression down to about 185 it was 200
So as soon as the rain lets up im goin to the track and see what shee will do
I have blown two dome orings on the same cylinder in three weeks i know a guy that said the high compression orings are hard to find
The bike runs bad ass as soon as i go through the trap and let off the gas it lets loose left cylinder compression oring
Every time i think one carb is running out of fuel before the other and going lean one plug is brown and the other is
A grayish almost white color on the side that took the shit. should i install a fuel pump its 1/8 mile the bike is on
Keihn35's with big bowls on alky any info would help
Just a simple small block motor lol port job, v force reeds, 35mm keihns on alky, big boss bowls and intakes
Hemi head 18cc domes, 8 degrees advance on timing, out frame pipes from wms , dynatek fs ignition,
Overide trans, oh yea 4mill strokin thats bout it
Look im 400lb laying it down on 4 jokes and some other shees around the way 7'15 all day
Consistant can anyone respect that? I get alot sh$t around about it what do yall think
