dunershee
Everything posted by dunershee
  1. So I'm running a tusk racing clutch with all of the stiff springs.the clutch is really hard to pull in. I'll be heading out to glamis next month and I was wondering if I'll be ok if I just throw stock springs back in or just do 3 stock and 3 stiff springs.. I'm not putting 2 much power out.. Just have t5s kn pods and 320 mains.. Running skat trak 20x10x10 9 paddle hauler.. Also lighter rear lonestar hubs.. Thanks for any input
  2. Its at the fairgrounds right? How do you sign up for it?
  3. Try cleaning out the carbs real good... when you take them apart.. With a small flat head screwdriver unscrew all the small jets inside the carbs and spary then out with some carb cleaner real good ..should get rid if any gunk that's clogged up in there..
  4. Mine use to do that... I had a cloged jet..clean them real good... should fix the problem..
  5. Order it.. Its like 45 bucks I think its cheap better safe then sorry
  6. Yes that would be fun... exept he doesn't know how to ride it yet and is likely to stall it off the line
  7. Funny thing.. My buddy got one of those new yfz fuel injected just the other day.. We took his and mine up 2 the dunes... I took him every run my quad is pretty much stock all its got is a set of t5s and all that good bolt on stuff... I have the traction (paddles) advantage tho.. And it was his first time out in the dunes... gatta love those high rpms on the shee
  8. I'll probably go if I have nothing coming up
  9. I'll be there... me and my buddy are leaving saturday morning
  10. Nothing major.. Wisco pistons t5s jet kit k&n .. Had boost bottle but took it of because I hear they are a waste
  11. Looks like haulers takes the cake! I'm ganna give them a shot! Always wanted to do sand wheelies
  12. Ok so I'm on the market for a set of padles when I bought my banshee it came with a set and I wasn't impressed (sand sharks) there where no better then my dirt tires... what do you guys think would be the best set of padles for my banshee to hook up and whole shot faster... the more cups the better? (My quad is not super moded ..just want a bit more traction ) What do most of you guys like running? Any info would be great.. Thanks..
  13. How's it going guys... I'm thinking of heading up 2 pismo the 21 any1 in? all my friends have trucks and I'm the only 1 with a shee and its no fun dunning with trucks that can't even keep up... so if any1 is intrested that be cool!
  14. How's it going guys... I'm thinking of heading up 2 pismo the 21 any1 in? all my friends have trucks and I'm the only 1 with a shee and its no fun dunning with trucks that can't even keep up... so if any1 is intrested that be cool!
  15. Thanks a lot... I will take a look at the sprokets and chain... I just noticed that I was missing the chain tensioner closest to the front sproket so I'll find one and hope that fixes the issue.. Thanks
  16. hows it going guys new here... so i got this problem with my 01 banshee.. my tranny seems 2 be slipping 1st and 2sec gear.. it only slips under load when i give it full throttle what i mean by slipping is it seems like is skipping a tooth on the tranny.. it shifts fine into all gears and rides fine at low speed but when i take off it seems like the tranny is skipping a tooth or something. also every time i change the gear oil i get ALOT of metal shavings... i just replaced the clutch and springs... any help would be great... THANKS!
