mxjim471
Everything posted by mxjim471
  1. Money is always an issue with the toys unfortunately. I thought all strokers were long rod. I just bought new Wisecos and would rather not have to buy new. What is a short rod stroker and where can I get such a crank assly? everything I've found is long rod.
  2. I have my cases split looking for a crank (even though I don't see anything wrong). Then a thought crossed my mind, should I put a stroker crank in? If I do, what other mods do I have to do (spacer plate, different pistons etc.) I just put a new top end in thinking that was the problem but it wasnt.
  3. Its wierd. Not pulling fuel mixture into the right cylinder. I switched reeds, cleaned the carb switched plug wires.I finally broke down and split the cases today. Don't see anythingmuch bad. Some aluminum chunks in the right side I believe from the last rebuild before I got it. You can tell the right side bearings went bad before. Wear on the cases and marks in the head,but all looks good now. Going to get a new crank assembly now. Possibly a stroker. idk
  4. I've been going round and round with my 98 with the same problem. Have good exhaust pressure coming out of the left side, no pressure on the right. Have another shee with no problems and have swapped reeds (since thats what was supposed to be wrong in the first place). Also just put new wiseco pistons in. Still the same thing, nothing on the right. Right exhaust pipe doesnt even get hot. Choke tube is on. Runs like it has an air leak somewhere. Idle revs high. Sprayed carb clean into the dead cylinder and that doesnt help. WTF! Thought it may be the right crank seal but its not smoking out of the right like it is burning it. Any ideas???
