KhromeShee
Everything posted by KhromeShee
  1. thanks man, appreciate it
  2. Hey im putting a brand new 41 tooth sprocket on the rear, and a new 13 tooth sprocket on the front instead of the stock 14 tooth. Im also buying a new D.I.D. ATV 520 x ring chain. Can I order a stock 104 link and adjust it, or do I need a differnt number of links? Im going 1 tooth smaller in the front for more bottom end.
  3. I had the same problem. quickest way to fix that problem i found was to shorten the tie rods a couple threads. If you look at your stearing stem knuckle you will prob see powder coat missing from the stearing stop tab.
  4. thanks got the 10% code on google.
  5. Buying 500 dollars worth of stuff off of Rm ATV web site, and want to save some money.
  6. they mount best on 9 inch beadlock wheels. no tire machine needed. just alittle dish soap. they dont ride as well as a holeshot or razar tire but will perform alot better in many different terrains.
  7. I do the same riding as you do, and ive found the best for me is fast trekkers in the front because they grab in the corners, and realtors in the back. they are heavy but you can climb sand hills and go through mud and water with no problem. i had holeshots for one ride and got stuck about six times, so i had to switch back to my normal tires that had never let me down. just my opinion
  8. thanks for the replies, i think ill do some research on that 4 gal ims tank.
  9. thanks, i was thinking the same thing about the gas can idea, but i didnt know if it would stay on with alot of woods and whopps riding.
  10. Hey whats up, I need a bigger fuel tank for longer rides and dont want to cut my plastics. Is their a tank that fits well and looks stock or would i have to get one of those stupid looking tanks that stick up real high?
  11. Prob should of been in different catagory. sry
  12. I dont know if there are any Realtor fans out there, but i sure am and could not find them for the longest time. I thought they didnt sell them any more. Finally found them at (Ronnies Mail Order). 67 dollars a tire. i know they are heavy but they work great in any terrain and sure thow alot of rock. :thumbsup: figured id let who ever was looking for these tires know where to get them.
  13. hey whats up. this is my first post and trying the best i can at it. my left wheel is facing outward, and when i turn to left and start to move the bike forward the tire then rubs on the A arm. i recently went rideing this weekend and slid into a tree. the tree pushed into the inside of the tire. im guessing something got tweaked. any idea what? tie rod looks fine, and i dont know what else it could be.
