abotto88
abotto88's Achievements
  1. you maybe on to something there, might have to check it out. As for the stator, when I pulled the cover off it didnt appear to have to much water in there, but i suppose this could still be an issue. Could it be the spark pickup gap?
  2. tors has been removed bro, pulled the stator cover off and sprayed a heap of water disperesnt in there so all the moisture should have been removed
  3. Hey guys, So here is my problem, I went through a bit of water a couple of weeks ago and about 1-2 an hour later the only way I could start it was pull starting, but at low rpms I would lose spark and it would die. After pull starting 4 times I lost spark altogether and it would not even pullstart. So I pulled the stator cover off and sprayed everything with a water dispersant and unclipped all connections and sprayed them. I had a spare coil so I wacked that in and it fired over first kick. Took it for a bit of a run and it went fine. Next day I went to start it and it was like I had a inconsistent spark, would fire but would not idle at all. So I put the original coil back in (The one that went through water) Fired like 2nd kick, Same deal again took it for a ride and went fine. Tryed to start it next morning and same thing will fire every 5 kicks but wont idle. Please Help this has really got me stumped
  4. yeh i tried taking the lid off, it went alot better but it made it very hard to start. Any suggestions on Jetting anyone like what Mains I could run and what pilots
  5. Hey Guys Have started doing a build on my banshee and need some help with my jetting. Info on bike 05 Banshee Standard Bore K&N Filter with Snorkel removed but with lid on Bill's Power pipes and Silencers Already has 270 Mains and Stock (25) Pilots Standard Reeds Stock head Stock Carbs 32:1 Mix ratio and use 95 octane fuel I ride in temprature anywhere between 10 degrees Celcius to 40 degress Celcius I ride at Sea Level to 200ft ASL I am going to add an adjustable timing plate at +4 Before I pulled it all down i noticed that it was bogging a little bit off idle but when it came on band it hit very hard and when starting it cold it sometimes back fired. Given this information I have provided could one of you please give me a couple of pointers on what my jetting should be. Cheers Adrian Australia
