Badapwned
Everything posted by Badapwned
Not to be an ass, buts its venturi....lol
Leaving boost bottle ports open to suck more air in?
Badapwned replied to Badapwned's topic in Banshee Repairs and Mods
Monroe, MI. Its like 20 min south of detroit -
Perfect, you answered all my questions. Thanks.
I dont do the plug chops, I do the same WOT run, then pull the plug and look at it. Looking at the bottom ring may be the most exact method, but im not drag racing, as long as its got the brown plug color im looking for, im happy. So, are you saying I will not be accelerating faster? I know the gears wont be as long, but that would mean to me that im accelerating faster, correct?
So your saying, gearing it down to 60 MPH from 70 MPH wont do anything for me? Everyone keeps telling me 380 is huge, but I could get zero plug color with anything smaller then that. The last plug check i did was with 360's and the plugs had no color. If anything the plugs looked lean. They were starting to get that slightly white look, like a lean condition. Once I put the 380's in I finally got a brown color on my plugs. Bike runs great with the 380's in. It never bogs or spits or anything at WOT. Runs great throughout the RPM range. It takes the gas and grins back at me lol
Well, stock carbs, 380 mains, cyl have been ported (not real aggressive, but has had some porting), FMF pipes, +4 timing, pod filters. I would assume the max rpm on the shee is not much more then a stock one. Considering the minor engine work.....
Well, the only reason to gear it down is that i have no place to go 70 + MPH. Its wasted gearing for me. 60 MPH is more then enough. Might as well get more acceleration right?
Whats the max RPM on a banshee? Is it around 9,000?
Damn, thats a good point. I know this question isnt referring to me, but...damn lol
Think I should take that into consideration when buying new sprockets? Im assuming right now I have stock sprockets. I pretty much toped out at 72 MPH in deep soft dirt. So, If I use the calculator, its pretty accurate to what I have. Should I just assume its perfectly right and buy sprockets to what it says? lol I want to achieve around 60 MPH max speed. So, I could use 13 front and 45 rear, and get roughly 62 MPH with a 20" tire. Or from anyone's experience is this to much or to little gearing?
6 MPH off which way? It shows your top speed to high or to low?
I was searching the forum to find some topics about gearing.... I came across this nifty calculator... http://home.earthlink.net/~gellett/banshee.htm Is this thing accurate? From my gearing and my tire size, etc. It seams pretty inline with a GPS I used to track top speed. My real question, if i gear it down from 72 MPH to 61 MPH, think I will notice anything on the bottom end? I have no reason to go 72 MPH, 60 is more then enough for trails, tracks and dunes right? So I can take the top speed down and get more bottom acceleration.....right?
hrmm, doing some quick math, correct me if im wrong..... 350 cc's @ 6,000 RPM = 74.16 CFM Sooo, this fan http://www.newegg.com/Product/Product.aspx...N82E16811999122 would have more then enough airflow then required for a stock bore and stroke banshee..... Correct? Wait a minute, im not sure what the max RPM is on a banshee. I would have to assume its more then 6,000 RPM. -
I completely agree. I forgot to add it was an external power source. The battery pack was not related to the engine. -
lol, can you point to a MPH calculator? Or some formula to determine a maximum speed on a banshee? I got 20" tires in the back, and im assuming stock gearing. Full throttle for 5 - 10 seconds in deep dirt, in 6th left me at 70 mph. I want to gear it down to 60 MPH, so my bottom end is quicker? Any advice? Again, im assuming I have stock gearing -
Sorry bud, only been to NJ for sales calls. I live in MI. So, I hope by now everyone has got it out their system. Im ready to move on...........to the next crazy question!!!!!!! BTW, I have tried this next idea. Putting an electric fan after the air filter to reduce pressure drop across the filter media. I guess essentially increasing air flow? I was throwing away some old computer stuff and I found this electric fan off an old CPU cooler. I took it off and mounted it after the air filter on my old KDX200. I wired it up to a battery and let the fan rip it up.....lol Basis: Well, a lot of computer fans can push up to several inches of water column. (there's approximately 27 IN WC in one PSI) So it would be a like an uber weak electric supercharger. The only thing I may have noticed was a minor increase in maximum RPM. Not sure though, this was like 6 years ago. Wuch ya guys think? -
Sounds like a good idea to me. :biggrin: -
Sounds like you answered your own question.... If I would have given it a serious thought, it would have been a better idea with more of a description.....correct? If everyone is so convinced I was being dead serious, heres my best thought. Adding adjustable venturi's to the openings to regulate air velocity, sort of like the old old carburetors. While having a fuel opening next to the venutri, when the pressure drop across the opening lowers, it sucks fuel in. The same way a real carb works. Essentially you have 4 carbs. A motor's power is only measured by how much air / fuel it can flow through in a pre-determined amount of time. The more air and fuel, the more power. There is my serious thought. -
Wait a minute, lets get something clear first. I am not upset or mad at anyone. Nor have I gotten mad over anything that has been said. Someone calls me a dumbass, so I simply reply back with the same comment. Probably calling the other person a dumbass in some way. Then someone else has some ridiculous comment, like oooo you like like your 17 lol. Because that's such an insult, so, I reply back with some type of comment. So as of now, X amount of people have tried to insult me in one way or another, and I simply reply back with a comment. I don't see why everything thinks im the one being hot headed. If you don't want a insultive reply back why try insulting somone in the first place??? -
Heres where I work, http://mon-env.com. Sure im young, ill be 21 in February. My g/f will be 22 in January. You guys are trying every angle? How about this for age, im twenty years old. Im already buying my first house, its 1,700 sqft. I own two bikes, a banshee and a cr250, and a 11 second 84 Trans Am that I drive every day in the summer. I have a 401k that I put money in every week, and right now im looking to buy a chevy truck. Im working full time, taking night classes. As far as im concerned, your age poses no limitation for what you can do. Save your money, Talk to the right people, Then act like them. What else you guys got? Gimme a break, im only defending your guy's attacking statements. You want to have a real conversation, lets switch the subject. -
Alright, im off to bed. Lord knows someone has to work tomorrow in the great state of Michigan. I am one of the few lol -
lol, I am also having a good time. I am cracking up just thinking about what someone else is going to say next lol I should be in bed too. I am waiting for the other guy to post its to damn funny to go to bed. haaha lol -
Not sure what this error message means, but here are links to my brand new photo bucket album wooooh!!! "Sorry, dynamic pages in the tags are not allowed" http://s359.photobucket.com/albums/oo32/19...nt=MeandAsh.jpg http://s359.photobucket.com/albums/oo32/19...ent=BoatPic.jpg Satisfied.......? :beer: -
hahahahhahahaahahahahaahha WHAT????!?!?!!? I didn't get any of that........ O wait, ya I did. The part where you sound like that little black kid from the movie Role Models. When he says "No I will not take off my pants".... Or something along the lines of that lol hahahahahhahahahahhaha Here, let me just add my pics onto your Photobucket albulm. You seem to be real active with taking pictures of yourself. Just let me add to your album, it will give you something else to look at. lol Sorry, that was to far. Seriously, is the only way to add pics is by attaching a link from another website? -
Right....who was accusing you of no g/f? Try looking up fag in the dictionary before you use the term. Could you please use your awesome posting skills to tell me how to put up a pic without putting it up on another website?
