Black01Shee
About Black01Shee
  • Birthday 07/27/1982
Contact Methods
  • AIM
    Warren350
  • Website URL
    http://
  • ICQ
    2001 Black (painted) Dynoport 2 into 1 Pipe K&N intake 260 Mains.
Black01Shee's Achievements
  1. Got it all figured out, after 10 wraps of the wire was no good tried 5 still the same problem, then i tried 2 and now it works perfectly. I also had to calibrate the speed and i did so by holding a gps while im riding and comparing the speeds. after several adjustemnts to the wheel size the right number for the stock front tire turned out to be 1490 if anyone needs to know.
  2. Ok i also ran into another problem, the rpm sensor is not reading correctly at above 6000 rpm it just jumps back down to like 4000 and becomes inaccurate. Im running BR8ES plugs and have the rpm wire wounded 10 times tightly around the spark plug wire by the spark plug.
  3. I got my trail tech vapor computer today i cant seem to figure out how to install the speed sensor/magnet thing. I did some searching already but cant find any solid answers can someone direct me step by step please. Thanks
  4. I just replaced my axle bearings/seals and so did my friend with another banshee. He got the all balls bearing and seal kit and i got new factory bearings and seals. I noticed that the all balls seals had little metal springs around the inside of the seals. and the factory seals did not. im guessing these are to make a tighter seal around the axle, will i be ok without those springs?
  5. Wont that scuff on the carrier allow dirt/water to get inside?
  6. Judging by the video you can see that wear caused by the rear sprocket you think ill be able to reuse it?
  7. Well i was riding today and out of nowhere my rear skidplate nailed a huge rock but everything seemed ok so i kept riding. About 10 minutes later i started to hear some metal clanking from the rear so i stop to check it out. The 2 of the 4 skidplate mounts ripped off and the skidplate was kinda danglin and thats what the noise was. So i figure no big deal ill order a new skidplate when i get home. I kept riding hittin jumps and stuff then all of a sudden the chain starts binding up, it gets really tight and then really loose. I get home and put the rear end up in the air and it looks like i must have damaged the bearings and carrier i think once the bearings went the rear sprocket started to wear into the carrier. What should i do i think im gonna need to replace the carrier and bearings how hard is it to do anyone have any links to step by step directions? thanks for any help Heres a vid so you guys can see what im talking about http://www.youtube.com/watch?v=pfAadEhsvZo
  8. All i got is a Dynoprot 2 into 1 Pipe and Modquad 2 into 1 intake system No snorkel 260 mains.
  9. OK im having an idle problem and it all started when i decided to unscrew that 8mm bolt inside the throttle assembly that holds all the throttle plates together. After i retightened it my bike only idles sometimes and when it doesnt i snap the throttle a couple times and then itll idle fine again. I know its that damn little tors button inside the throttle assembly. I think its just not being pushed at the right time now when i let go off the throttle and makes the bike die. Heres a video so you can see what im talking about http://www.youtube.com/watch?v=Tismjml5NiE...re=channel_page What is the proper way that throttle assembly with that 8mm bolt needs to be adjusted to.
  10. I see, well im looking for any kind of mods i want to gain some hp but not loose any reliabilty i do mostly woods riding with a few 6th gear wot runs here and there. I read about advancing the timing +4 how can i do that?
  11. Me and my buddy bought 2 banshees and we want to do some mods. He says hes gonna give his bike to this shop that he knows about to tune it (its not running properly) and he said the guy at the shop will put some kind of a pin in the flyweel and that will give it 2 more HP is that possible? how does that work? also what are some easy to do mods that i can do myself to mine (i have good mechanical ability). I already have 2 into 1 dynoport exhuast.
  12. first ill try #5, #3 wont work becuase i already loosened out the adjusters all the way and there was still a little clearance between the end of the adjusting bolt and the axle housing and i tried prying it to move it a little more but it wont, its defenetly at its loosest setting so the next step ill do is #4 if this chain dont work out. thanks for your help guys
  13. I have a little slack its not super tight, like i said theres about 1/2 inch of chain movement.
  14. you mean itll wear out so that itll be ok soon or wear out to the point where the chain is garbage. The adjustment is already at the loosest setting.
  15. My chain was really lose and i also installed a 13 tooth in the front so it eas even looser after that, so i pulled a link and now its really tight, even after the adjusters are all the way out. There is about 1/2 inch of play on the top part of the chain between the front and back sprocket, should i be worried? will it loosen up eventually from riding?
