redcupra
About redcupra
  • Birthday 02/14/1981
Contact Methods
    portugal
redcupra's Achievements
  1. thanks my friends
  2. Are you saying then to keep the tube of the rear crank case vent and vent under the waterpump cover as if the original circuit?
  3. you right about that tube. i forgot that i think now i understant. but if a eliminate the tank you say to put in this way, correct?
  4. is this the correct way? what cam i eliminate?
  5. i think i understand everything. so 1 can eliminate the small tank? or just the tubes that conect the water pump and the back of the motor? tomorrow i take pictures to see if are everything allrigth thanks
  6. i had my banshee stoped 2 years and now i want to rebuild it. i only have 1 doubt. the litle tubes of the water circuit. where are they conect? if someone have pictures of that help. or if someone could explain to me. thanks. im portugues and my english is not so good
  7. i had the same problem. it was the reeds cage its broken
  8. the stator of the rd 350 works with the pcdi-10v??? if work its more simple to me to do the wiring
  9. i put the baterry im front of the steering colun. and im gonna make the electrical wiring all from zero. and i have to cut the part of the carb because they have something electric
