gattaca37
About gattaca37
  • Birthday 07/18/1978
Contact Methods
  • Website URL
    http://
  • ICQ
    Sparta, MI
  • Interests
    Riding all types
    2000 banshee, prodesign coolhead (15,18,20cc), k&n prechargers, +2 +1 a-arms works, trl rates, port and semipolish, -2 swingarm, custom frame, custom paints,+7 degree key, .060 over wiesco pro-lites
gattaca37's Achievements
  1. the banshee will run like shit when 1st started, this problem just started. I am running the same jetting as 2 years ago, made sure the carbs were clean and synchronized. k&ns are clean and played with the air screw in carbs. She will act doggish (3-5 min) in 1-3 gears: 4-6 she will run great. Duncan said could be the rings, (weisco rings go bad they said) there is quite a bit of black residue coming out of flange & pipe. Sometimes she will foul a plug on this cylinder. Compression could be low I was told? I had the compression so low that I had to be pulled to start, I can start on 1st kick. Maybe the reeds, a season ago i replaced 1 side and I am guessing I replaced the right cylinder cause the left is giving me problems. I was running 93 with boost before and then I just went to 93 (cool head with 18cc, told I could run pump gas), do you think because I dropped the octane? No predetonation or knock, though. Tell what you guys think? thanks
  2. VOTE TOMORROW, VOTE REPUBLICAN AND KEEP THE ATV INDUSTRY ALIVE!!! KERRY IS CUTTING THE ATV AND SNOWMOBILE TRAILS IN HALF!!!!!!!!!!!!!!!EVEN IF YOU ARE MAD AT BUSH FOR THE WAR, STILL VOTE REPUBLICAN. SO WE LET UP IN IRAQ AND BRING THE BOYS HOME, THEN THE TERRORISM STARTS IN THE U.S. AGAIN. TELL EVERYONE YOU KNOW WHAT WILL HAPPEN WITH KERRY AND WHY TO VOTE REPUBLICAN!!!!!!!!!!!! KERRY SAYS THAT HE'LL MAKE THIS BETTER AND THIS BETTER, WELL IF PUT IN TO PRESIDENCY, NONE OF THESE CHANGES WILL OCCUR (INSIDE SOURCES STATE). VOTE REPUBLICAN!!!!!!!!!!!!!
  3. VOTE TOMORROW, VOTE REPUBLICAN AND KEEP THE ATV INDUSTRY ALIVE!!! KERRY IS CUTTING THE ATV AND SNOWMOBILE TRAILS IN HALF!!!!!!!!!!!!!!!EVEN IF YOU ARE MAD AT BUSH FOR THE WAR, STILL VOTE REPUBLICAN. SO WE LET UP IN IRAQ AND BRING THE BOYS HOME, THEN THE TERRORISM STARTS IN THE U.S. AGAIN. TELL EVERYONE YOU KNOW WHAT WILL HAPPEN WITH KERRY AND WHY TO VOTE REPUBLICAN!!!!!!!!!!!! KERRY SAYS THAT HE'LL MAKE THIS BETTER AND THIS BETTER, WELL IF PUT IN TO PRESIDENCY, NONE OF THESE CHANGES WILL OCCUR (INSIDE SOURCES STATE). VOTE REPUBLICAN!!!!!!!!!!!!!
  4. VOTE TOMORROW, VOTE REPUBLICAN AND KEEP THE ATV INDUSTRY ALIVE!!! KERRY IS CUTTING THE ATV AND SNOWMOBILE TRAILS IN HALF!!!!!!!!!!!!!!!EVEN IF YOU ARE MAD AT BUSH FOR THE WAR, STILL VOTE REPUBLICAN. SO WE LET UP IN IRAQ AND BRING THE BOYS HOME, THEN THE TERRORISM STARTS IN THE U.S. AGAIN. TELL EVERYONE YOU KNOW WHAT WILL HAPPEN WITH KERRY AND WHY TO VOTE REPUBLICAN!!!!!!!!!!!! KERRY SAYS THAT HE'LL MAKE THIS BETTER AND THIS BETTER, WELL IF PUT IN TO PRESIDENCY, NONE OF THESE CHANGES WILL OCCUR (INSIDE SOURCES STATE). VOTE REPUBLICAN!!!!!!!!!!!!!!!!!!
  5. MAKE SURE TO VOTE REPUBLICAN ON 11-2!!!! REPUBLICANS KEEP LAND SAFE AND TRAILS OPEN TO ATV ENTHUSIASTS! DEMOCRATS TRY TO CLOSE DOWN LAND, AND MAKE ENVIROMENTALLY SAFE. IF KERRY IS ELECTED, THE EPA CHIEF IS BOBBY KENNEDY JR., THIS MEANS KISS GOODBYE TO ALL 2-STROKES AND HIGH RESTRICATIONS ON SOUND LEVELS AND EMISSIONS FOR THE 4-STROKES. bILL CLINTON IS A DEMOCRAT AND HE SHUT DOWN 70,000 ACRES OUT OF 450,000 AT GLAMIS. SO DO IT FOR YOURSELF, A FRIEND, AND YOUR CHILDREN, VOTE REPUBLICAN!!!!! KEEP OUR FUTURE SAFE!!!!!!!!!!!!!!!!!!!!!!!!
  6. WHo chromes in Michigan near the Grand Rapids side? I need Triple plate and this would only be small jobs (2 sets of pipes).
  7. I run the 50:1, but During the spring-fall I run it at 80:1 and she stills smokes a little and the plugs are beautiful. I love amsoil!!!!!
  8. 2001 banshee, T5 pipes and silencers, open k&ns, renthal bars, custom paint, mint condition, very little use, call Patrick 616-291-8980, $3700 email [email protected] and we will send a better photo
  9. I have a complete stock 250r silencer and pipe in mint condition for sale asking $100. Call John @ 616-887-9302
  10. 2 sparky spark arrestors for toomeys. Paid $150 asking $100, great condition, call John @616-887-9302
  11. Have cylinder and head. mint condition, Only bored .020 over , bought 240 kit, asking $200 Call John @616-887-9302
  12. have a +10 custom swingarm for a banshee. Uses stock axle carrier. Asking $250 Call John at 616-887-9302
  13. basket is off (the whole clutch side is gutted out, every thing inside of cover) and she is catching, when in gear being pushed to makr the shaft rotate (which it would do at all times when engine is just running) I am able to see and hear her catch, making the noise. The 2 shafts must have something out of place. It has to be something out of place because every revolution there is a ting at the same time. You speed up engine the ting speeds up.
  14. thanks
  15. What is banshee zones website. thanks
