scott-f4i
Everything posted by scott-f4i
  1. any other ideas ????
  2. the entire tors ssystem was already deleted , as was the key . they did however have the key grounded to the parking brake wire . im currently rebuilding the harness cause the ground connection for the coil looked a little shady .
  3. just starts and stalls . and this is the first attempt at starting. ive tested the stator , it ohms out fine. im lost
  4. thanks , at least now i know what it is . i still have no idea what would cause it to stall immediately after it starts . anybody else have any ideas ?
  5. hey guys , i need some help . i bought a project banshee a while ago , assembled it and am having an issue . when i kick it , it will start and run for a second or two , then stalls out . ive pulled the carb , checked for clogged jets / and debris , tested for fuel flow at the petcock and the bowl . its gettin plenty of fuel . the left cyl doesnt seem to be firing all the time either . i just cut the harness apart to check for issues there , everything seems good but one question i have is what / where does the green with yellow tracer wire coming out of the clear plug on the cdi go ??? its just cut a few ft into the harness and i cant find it in any diagrams online. general set up on the bike currently is sst pipes , trinity 2 into 1 w/33 pwk carb ,k&n pod w/ outerwear , boysen reeds +4 timing and a gytr cdi. tors and key switch have been deleted and completely removed from the harness. any help would be greatly appreciated . scott
  6. thanks again and good meeting you
  7. how much for the stator shipped to 07405 ? is it stock or ????
