My Banshee leaks quite a bit of gas from what the manual I have calls the "drain hose" of each carb. Not the "vent hose" which is higher but the very bottom drain hose. There is also a "drain screw" which I have tried tightening a bit but both seem semi stripped out or something they don't go tight. It leaks a LOT if I have the bike off and leave the gas valve on, not so much or barely at all if bike is running and using gas. My question is, is this indeed just a drain and I havea problem with the screws not totally closing, in which case can I just remove the hoses that lead under the bike and cap off the fitting so it no longer leaks. Or, is this more of a fuel bowl overflow situation, indicating a float problem in both carbs and its leaking overflow and probably flooding the bike as well?
