Heavymod
1 Follower
About Heavymod
  • Birthday 10/14/1950
    Billings, MT
    2000 Banshee with frame mods, 552 Cheetah on Methanol built by LC Performance, 2-5 override tranny and CPI drag pipes
Heavymod's Achievements
  1. Our lights don't have the computor program for mph yet.
  2. When I raced Brett, I didn't have the motor reved-up enough....so I bogged out of the gate and had to clutch it again. This track was very heavy with the massive down-pour we had the night before. Rob and me ran 4.1s with the 12mill alky Banshees and Rob pulled off a 4.0 run for the fasted time of the day. Jeff, you will have to bring that 4mill here...I bet you would be running mid 4s with our crappy air here. Our track is basically on flat ground with a rise about mid track...it needs to be leveled-out to be perfect.
  3. All the hot rod Raptors got 2-Stroked this weekend at St. Anthony...lol!!! There were a few Raptor guys that didn't like getting pounded by Brett's 4mill. Norm's 843 Raptor on nitrous was the closest race for Brett.
  4. I feel these billet forks would be a wise investment....after all, like myself, we have pretty good money tied-up in the override tranny. It's a no brainer!!
  5. It is a 552 Cheetah 12 mill stroker on methanol and was ported by Lynn at LC Performance. Has 38mm Mikuni carbs bored to 40mm with alky conversion. Has the jet style power jet. Has a very wicked fast power band when launching. Had to remove the +12 swingarm and go to a +14 White Knuckle ladder style swingarm to keep the front from lifting so bad.
  6. Don't know what to tell ya....but that was the color scheme for my son's build.
  7. I think K&Q Fabrication built it. We bought it off Ebay and had the chrome stripped by Metal Master in Salt Lake and had it powdercoated in Billings by PowderKote Unlimited. If you go to YFZ Tech, it looks exactly like their work.
  8. I have a +12 chromoly ladder bar swingarm with caged needle bearings for sale. We had it on my son's 12mill alky Banshee for one trip to St. Anthony. Anyway, we had to go to a +14 swingarm to keep the front-end from lifting so bad. It is 1 inch tubing with 3/4 inch cross tubes and is powdercoated wet black. Asking $400 shipped or make me an offer. Sorry about the small pics, I will have to have my son post larger pics later.
  9. Call Lynn at LC Performance...he can tell you the recommended changes to run nitrous.
  10. When we started kolb02's 4mill with the 1-5 nuetral down override duneable extreme , it started making a grindy noise like it was trying to engage into gear in nuetral. Like he said we shut it off and started it again and the noise quit. After hearing about the problems, I told my customer that it would be wise to pull the tranny out and go with a regular duneable override or have this one checked out. We pulled the motor tonite to remove the tranny and we are steering toward a proven duneable override, instead of taking a chance on the extreme override.
  11. We powdercoated my son's(686raptor) CPI drag pipes on his Banshee with the high temp black...holds-up just fine and looks good. We powdercoated his drag pipes for his 760 Raptor and they held up good to the 4-stroke exhaust temps.
  12. CPI OOF on alky
  13. Sounds like to me that 7 degrees timing might be a little too much timing...I would back it down to at least 5 degrees timing. Sounds like it is pre detonating at 7 degrees. We have had plugs starting to loosen up at 5 degrees with 110 octane race fuel. We usually run Sunoco or Turbo Blue.
