KG03Banshe
Everything posted by KG03Banshe
  1. I just had a Yamaha service shop look at the gear box and they said nothing is wrong. But yet the transmission locked up when riding it. New question: Should you be able to shift through all the gears with the bike sitting still (motor in or out of the bike).????
  2. The forks and shafts seem to be fine. I took out the gears and the shift star detent and just rolled the barrel and nothing was binding. But when I rolled the barrel with the gears in the dogs kept getting pushed up against the next gear and the whole assembly stopped. I didn't adjust anything yet, what adjustment are you talking about???
  3. I have a similiar problem to this guy. My case is also apart because the bike gets stuck in between gears. You can see it happening when you try to shift it through the gears, the dogs get stuck up against the gear they are trying to go into. Then the assembly is stuck untill you physically spin the gears by hand? Whats up with that???
  4. 03 Banshee will not shift through all gears without getting stuck halfway between. The shift mechansism works properly. We took out the gear sets and shifted through all the positions with no issues. When the gearsets are in the gears will clash and not allow the shafts to lock together. No bent shift forks, no broken teeth, no abnormal wear... NEED HELP??
