D-man
Everything posted by D-man
  1. whats the biggest you can get cc wise and the shee still be woods and trail worthy?
  2. so which xmitter bar would be better than stock but not overly expensive?
  3. Dremel, files and sand papper. work slow. you can take it off but you cant put it back on.
  4. i know this is a touchy subject. ive done port clean ups before. this time i want to port match the case and sleeve. are there any pointers you guys can give me or some advice? some tips on how to do it correctly? i know i wont get a pro job out of this. i dont have the money to spend to get the cylinders ported by someone tho. what ports should i change? what ports shouldnt i change? im a beginner to doing any heavy modding to ports. like i said ive only cleaned them up.
  5. you could find somewhere to mount a new battery. hook lights directly to the battery. every time you get done ridding unhook the battery pull it out and charge it. i think this would be easier than getting a stator thats possibly shit.
  6. raptor is like a cheap hooker with every disease known to man.an ugly banshee is a high class whore that spends the night and washes your car.
  7. i know its not a good idea but you could run it till is doesnt run anymore.
  8. you could always get rid of the craptor and take that money and put it into the banshee.
  9. you could probably be ok if you just drained it. make sure the case is very clean on the spot your going to weld. that makes tig welding a lot easier and it loos nicer. if its not a huge gap you should be ok welding it without taking apart the motor.
  10. if you or someone you know is good with a tig welder you could try and weld the hole or weld something over the hole.
  11. port the piston sleeve to match the ports in the block. dont mean to high jack the thread but would it be hard for a d.i.y.er to port and polish the motor?
  12. im going to be getting a banshee soon. i need to know what years to stay away from. i do know this im going to be ridding trial and sometimes dirt roads. i might take it to the dunes every once in a while. what mods should i do to the banshee after i get it? im probably going to be getting it off craigslist so what are some stuff i should look at once i get it?
