Hey Guys,
Have a 2001 banshee rebuilt top end, boysen reeds, fmf sst pipes and k&n filter with box and lid still on. Running 30 pilots, 2 turns out, 270 mains, needle 3rd clip @1800FT. It ran fine 2 years ago and since then its hasn't run much. Cleaned out the carbs and draned the old fuel. Installed new plugs. I have no air leaks. Basically when the bike is cold i pull the choke out all the way and it will run after 2 or 3 kicks. THen it runs for 3-5 seconds and then stalls. Then its just a nightmare to try and get running. It will start then stall and keeps doing that. Eventually it will run and then i can rev it up and it will warm up and then run fine. Will start with one kick once warm. THen i leave it for a few days and the samething happens. I've tried 25, 27.5, 30 pilots and all postions on the air screws. Adjusted the idle scews, carbs are synced. Choke tube is good. I'm starting to lean towars the stater/coil or spark issue. Spark seems good. but bike will start idle fine for 2-3 seconds and then die. I have to get it running and then rev it when it cold to get it to idle, if i don't rev it just dies like the spark is cutting out.
Anybody got any ideas?
Shaun
