ramboner69
Everything posted by ramboner69
  1. i had a similar issue with a bad coil..and on my other the timing plate broke that holds the pick up coil in place..jus some ideas
  2. no i didnt get ur pm
  3. i believe the wheels are a polished itp or douglass just a plain style with so so tires
  4. i have a botton end the shift shaft is a little bent but dosent affect the motor
  5. parting my 02 banshee has fmf sst pipes with power core 2 silencers...one head pipe is dented up a bit brand new chain and sprockets set 31-41 never used yellow drag cut plastics with tank and rad cover & custom blk/yellow seat complete motor carbs brakes frame and everything else from a stock banshee make me an offer on any parts u want if using paypal add 3%
  6. if u ever decide to part with it ill deff take those side engine covers
  7. personally if you are semi mechanilly skilled id buy a 1/2 decent compression tester and give that a whirl for the money for a tester i like to be safe...and check over everything every1 else said..id ride it and make sure the tranny is good
  8. id be there if my shee wasnt down right now maybe the next time
  9. i have the red rad cover
  10. let me weigh the stuff tomorrow and ill let you know
  11. yes the have the rotors..25 shipped is a lil low im sure it will cost a lil bit to ship the stuff out
  12. i have some front hubs...sprocket hub brake disc hub...sterring stem gas tank..and some other misc stuff toss me an offer and there yours
  13. ive got an 03 w/ title fresh paint on frame and a arms..a arms were recently rebuit..newer top end about 12hrs on it mx ported cylinders boysen reeds fmf sst pipes have a few dents in the one side..new brakes..new fly bars..twist throttle..brand new chain and spockets 13-41..good tires yellow drag cut plastics with custom seat will have pics by the middle of the week if your intrested
  14. check the compression with a gauge
  15. trans is sold....ty lowbbuck
  16. mx ported cylinders .20 over with pistons milled head 20 thousands less than 7hrs on setup $320 shipped complete 02 tranny $120 shipped
  17. are chokeless carbs a big PIA? or will it be ok with warmer weather? any help
  18. i contacted the seller and he examined the cases n said they are NOT trenched so im gonna go with its a 4mm 5mm long rod he said his auction info was comming from the guy he purchased the motor from
  19. i contacted the seller and he examined the cases n said they are NOT trenched so im gonna go with its a 4mm 5mm long rod he said his auction info was comming from the guy he purchased the motor from
  20. i contacted the seller and he examined the cases n said they are NOT trenched so im gonna go with its a 4mm 5mm long rod he said his auction info was comming from the guy he purchased the motor from
  21. any advice on measuring the crank out of the bike?
  22. thats what i was thinkin but when i purchased it off ebay it stated it was a 5mm stroker crankshaft purchased from tdrracking.com for $800.....maybe the seller was uninformed but the 5mm crank on tdr is $800
  23. thats what i was thinkin but when i purchased it off ebay it stated it was a 5mm stroker crankshaft purchased from tdrracking.com for $800.....maybe the seller was uninformed but the 5mm crank on tdr is $800
