Rune
    Banshee engined ICC kart (bilding)
Rune's Achievements
  1. here are some port timing in mm http://home.mchsi.com/~xen-uno/2-stroke-timing-xen.xls
  2. Hi is it posible to use a EFI from a snowmobile engine Use all sensors/trottlebody and ecu and tune it with a programer. Could be a cheep whay to have a EFI ??
  3. Hi is there a weight advantages on the banshee engine vs the yfz450 engine
  4. Hi anybody have looked into mounting a YFZ basket to a banshee Why ? I want to use a recluse auto clutch whit a over ride (chose auto or manual clutch) there are not any made to the banshee at my knowledge's It wold bean great fore the tight stuff newer stalling the engine and been able to run more aggressive porting And still trail friendly :biggrin: regards from Norway
  5. Hi dose anybody have resleeved a RZ cylinder using a banshee sleeve. I`m bulding a RZ powered ICC kart (220lbs), and the engine have a bad crank so i`m thinking of bying a 7 or 10mm stroker crank and using a TDR 72mm sleeve. I also need new carbs (stock is gone) what carbs/inntake and reeds to by ? Regards from Norway
