04Leshee
    Black and red. 2004 Stock.
04Leshee's Achievements
  1. 3.60 here in newyork!
  2. Still UP!!
  3. Maybe someone can give me some info. i have a stock motor. and im in love with the looks of the paul turners. idc about low end, mid range, or top end. as long it improves over stock i'll be happy. what kinda pipes do they have? and what power increases do they offer?
  4. i can get. My mistake. 2003, not limited edition. black and red.
  5. 2004 limited edition shee with cash?
  6. should the tube inside of the carrier come out??
  7. Trade 2004 stock shee for a 4 stroke. 400ex, z400 something like that. tors kit removed, filter, filter adapter. stock.
  8. i already have the bearings so is it worth puttin it all back together and riding it? i've had so much down time since i've bought it. should i buy a stock carrier? or an aftermarket one.? and in the middle of the carrier, the metal tube thingy. is that suposed to come out? i can take pictures and post them??
  9. Rear axle bearings went. on the sprocket side of the carrier a half of the bearing is stuck inside of the carrier. and its chewed up on the outer part of the carrier. i know i have to do a little grindin on the carrier to make the bearing go on.. but how do i take out the old bearing on the brake disc side? and take out the half of bearing on the sprocket side?
  10. I also have a 04 shee and im having the same problem.. replaced the Coil pack.. and now its moody..
  11. he "rebuilt the topend" i dont know if he did. i was told so. Also he cleaned the carbs synched them and did the air screws. Unsure if he did it right..i havnt had a chance to fiddle with anything i was just seeing if maybe this was common. it blows smoke like its runnin rich outa the left pipe. after 35mins of riding itll bog and shut off. wont start untill 15 mins of lettin sit. idk if thats common either? im sure i got alot of work ahead of me.
  12. Replaced coil,due to only sparking on one side. Blows more smoke outa the left side then right. low end sucks.. Mid range has more then Topend. All stock.. previous owner did his own "repairs" cleaning carbs,blah blah Wondering what i can do to regain all around power.. While remainin stock. Just wonderin if there is anything he could have messed up Oh has tors kit removed. any help is appreciated.
