fryball2001
Everything posted by fryball2001
  1. i can shift up on my bike but i cant shift down can you give me a hint on my problem. can you tell me the cheapest place for 33mm carbs the whole kit
  2. I have vforce reeds port polish 2 in 1 38mm carb cpi inframe 18 cc domes in coolhead run c12. bike run great until i hit 5 and 6th gear it starts to bog whats the problem need help.
  3. thanks for help
  4. boring .90 over is this good and what do u think i should do
  5. 18cc, run mostly open fields and drag a little
  6. do run 93 pump full race fuel or 50/50. what type of race fuel to run
  7. i have duncan racing power heads do u have to buy ducan racing domes or what other domes or compatible with these heads
  8. it idle good and revs good but when i put in first and go it bog then she runs great
  9. i have 2 into 1 38mm kehin carb port polish coolhead 19cc reeds. now when i hit throttle it lags untils it hit powerband then she runs great can u tell me whats wrong so i could get my throttle response back
  10. need 33 pwk or 34pj with intakes
  11. I live in south louisiana so my elev is low ill find out if i have timing today. i do run wot for a little while. but sometimes i dont but im getting a compression tester today. so ill let u know what it reads
  12. Do u think i need race gas to be safe and i going to by compression tester today
  13. it has mild port polish vf reeds and have 38mm 2 in 1 carb and by the way what i have to do to convert back to dual carbs
  14. i think 20cc run 93 octane runs fine through all gear but hesitate at top of 6th but thats were i think my plugs started to unscrew
  15. The whole plug unscrews out my coolheads. the guy said just tighten when it cold
  16. when i ride spark plugs keep getting loose can you help me with this problem thanks
  17. will i be able 2 beat the 4 strokes . will i lose a lot on top end
  18. i will run 38mm but i dont just race i ride open fields and trails too. i want to know will i still be able to smoke 4 strokes
  19. what do you'll mean about losing top end will it slow down. do u think it good for 300 ft drags
  20. whats the difference between 2 into 1 carb and twin carbs. which setup is better
  21. shaved head vs cool head. and reed spacers with boysen reeds or vforce reeds. and whats their differences
  22. I need new front brake system. complete were can i find and who has the cheapest price
  23. just like the title were can i find the cheapest v force 3 reeds
  24. I want to know whats to best 2 stroke oil to run in a banshee
