dieseltwitch
About dieseltwitch
  • Birthday 08/14/1983
Contact Methods
  • AIM
    MrDieselTwitch
  • MSN
  • Website URL
    http://www.dieseltwitch.com/yfz450
  • Yahoo
    Dieseltwitch
    Strasburg Co
    99' Color UNK. Bike still under construction
dieseltwitch's Achievements
  1. I got a WORKING! 600R motor for 100$ the bike crashed and tore the front end off but the motor still runs just fine. no damage at all. I want to mount it in a Shee frame i have. i just want to see what other people have done. searching for street bike motors in banshee frames doesnt bring up much on Google. so you just wondering what other people have done. my biggest questions are..... How to route the EXH and how to fix up the swing arm mount. just another one of my never ending projects. I just noticed i have it the topic listed at YFZ600R it should be YZF600R sorry guys
  2. I did this on 2 of the studs and they came right out others i just striped the threads right off hey guys thanks for the advice i'm gona try it today and see what works, thanks again
  3. I dont really understand what you where saying i think you where talking about having the piston running into the head. but i not really sure. a bit hard to understand what you where saying. as for the grove porting i just didn't know what it was really called at the time so i just kind of jumbled some word together and called it good
  4. Sounds like no matter what carnage will insue! o well!
  5. I've tried and tried to get both the front and rear motor mounts out on the upper case, short of drilling them out how do you get them out? they are dry rotted and need to be replaced
  6. Cool thank you for the heads up
  7. Yeah is rigth where the con rod is. the lower con rod let go and gouges it up, the dropletts are just watter. and i dug most of the baring metal out
  8. I'm going over and rebuilding the motor. its been sitting for 2 yrs and a lot of the stuff is rusted out. that and now i have no way around it! thanks for the advice. all i have is a cutting torch with a brazing tip that i will run as low as possible
  9. Ok so i got some of the studs that hold the cylinders down out but others just wont move. any ideas! i've been using vice grips. i even ground down flats to get a better hold and nothing!
  10. so what do i do about the heave gouging of the crank case
  11. Ok guys so heres my problem, my #1 Lower Rod Bearing let loss and gouged the bottom of the crank case nicely! im planing on puting a +4 mm stroker but i have never done this before. do i need to get the crank chase machined to accepet these parts? Im guessing that with a +4 crank that i will have to take off 2mm all the way around on the sides? am i wrong? help me!
  12. not that your wrong but why does trinity suck so bad! you get burned?
  13. It was well over a year ago when i read the arctical about the style of proting as i remember it, he talked about how the frame front was able to prgress to the squash band faster and. or somthing. i know it had nothing to do with fuel atamization. also im working on finding parts for my motor. and you say that trinity sucks ass... what about the cheetah cylinders are they made my trinity or just sold by them. I was thinking about going with the 421cc kit (4+mm) any thoughts
  14. http://www.trinityracing.com/products/yama...heeheadmod.html here is kind of what im talking about, the one i saw had deeper groves and they didnt coil out. they where straint and alot deeper! think this is a lot of BS or what do you guy thing?
