Coupelx
    8
Everything posted by Coupelx
  1. We weren't saying the rod damage was going to affect it. We were correcting false information. Something that needs to happen more often.
  2. Thats so wrong jared. You, me, blair, jennings know nothing!
  3. serious? Where do you come up with this stuff?
  4. Sounds like you have it all figured out. Make sure to remove the stock regulator. Probably use a 2.5 or 5 amp fuse with the hids. With the 15 something will burn up long before the fuse blows.
  5. Ill be showing up wednesday night in a baby blue 78 f150.
  6. I did some work on this bike which was originally bought from bhq 'r Colby. I dont know the current owner but when my buddy had it, it was a very clean and good running bike. It has 28mm pwks and a kn filter in addition to the pipes. Virgin engine with decent compression. http://oklahomacity.craigslist.org/mcy/3372947181.html
  7. I have some. One was mounted. Other has never been used. 30 shipped.
  8. Already getting stuff planned out. Gives my life some purpose other than the next case of beer!
  9. you are the one I was thinking of. Lets see some pics!
  10. Many say you are paying for the name but like finch said they are damn good arms. I love mine. They pop up used for reasonable prices and zillafreak has some forsale.
  11. Trinity had to do something about that pesky problem.....
  12. I like to cut the whole glob off and trim as needed. Faster and easier for those not comfortable with soldering. Then lightly sand the coating off the wire and solder your new wire on.
  13. Stock boots will work. Filters should but it might be tight. As for jetting probably start with a 140 main and 40 pilot. I ran the lgn needle i think with t5 pipes. Disconnect the tors box by the coil and throw away. Use a cable for stock carbs WITHOUT tors.
  14. Already told work ill be missing in action.
  15. Gay as fuckin aids.
  16. Purge with what the fuck ever is cheapest. The motherfucker is idling. Its not gonna blow up or detonate or anything else. I don't even run alky and I know this.
  17. Hide draw less than the stickers...
  18. You will hook the regulator up to the yellow wire in the harness. The blue wire would probably work. It connects to the yellow wire. Just the grounds for the lights need to be changed.
  19. The wiring for the kill switch and cdi would need changed.
  20. You will have to either dig the ground wire out of the harness, cut it and run it to the battery or just run a whole new wire. I have my hids connected to the high beam wire. This way the lowbeam only turns on the tail light. High beam turns on everything.
  21. Mull did mine with the swirls. Dont know as to if it helps but the package as a whole works
  22. Yes there is 2 wires. Electricity 101, complete circuits. Anyways the wire you add and the existing yellow wire will go to the regulator. The black wire will stay hooked up as stock. Any lights you add must be grounded back to the battery and not the frame.
  23. Pull the dick out of your mouth.
