bansh4mil
Everything posted by bansh4mil
  1. This is a 4 mil stock cyl. setup for methenol built by DMR (Dave Moore Racing). Fresh top end with blaster pistons.The cylinders are drag ported by DMR for methenol with a ModQuad head with DMR 4 mil domes. V Force 2 reeds with new pedals, 34mm Mikuni Tm Carbs Bored to 36mm with DMR power jets and K&T over sized bowls. CPI both out left side drag pipes with DMR carbon fiber silencers. A new 8 plate clutch with a Hinson basket, ModQuad lockup and straight cut gears. The tranny is a WCR 2-5 neutral down dune able override. It has a Dyna ignition, drag radiator and drag tank. This bike has consistently been the fastest 4 mil stock cyl at Sand Mtn. NV being clocked at 75 MPH with a 208 lbs. rider. The frame is completely custom and light weight. +2 forward a arms with upper aluminum heims and steel lowers and chrome drag spindles. +10 ladder bar swingarm, solid motor mounts. DMR chrome 1 of a kind sub frame and grab bar. ModQuad drag axle. Marvin Shaw comps on the front and a hillshooter on the rear. Complete custom rear brake setup. Custom steering stem and bars. Front Direct Drive 10x2 5/8 spindle mounts with smooth triple buffs and rear 8x7 wheels with custom staggered Skat Trak 12 paddle triple buff 8 hauler 4 glider combos. I'm sure I have forgot a lot more. This bike weighs 260 lbs. ready to ride. This is a very clean, fast reliabe quad. I just don't have time to use it anymore. My loss your gain! $6000.00 OBO. Pink slip in hand. Call or text Link to Craigslist https://chico.craigslist.org/snw/4688694040.html
  2. I have a set of cpi small bore small flange both out left side with dave moore carbon fiber silencers, that I'm going to sell.
  3. Are group will be there sat morning
  4. Yep, on the lower left wheel that is a blob of soap not a scratch.
  5. Like is say's. I have a set of 8x7 drag cut wheels yamaha pattern, that are powdercoated black. They have a few nicks on the outer bead that could be touched up easily. $90.00 shipped
  6. 2 - 3.5 x 6 kn filters for 34mm carbs they fit 2 1/4 carbs. $30.00 shipped A swinger bolt with pivot tube and end caps with seals. Will also throw in a steering stem bearing and seals. $40.00 shipped A Modquad brake backing plate with the c-clip. Also has brake spacers, but they r from jjanda so I don't know if they will work. $25.00 shipped Front fender mounts powder coated a blue with green and some other flakes in it. $10.00 shipped Rear 6 bolt steel sprockets either sunstar or jt. $50 shipped for all of them. I have 3-45, 2- 46 , 1-48 Rectifier you can have it if you buy something or pay the shipping.
  7. These are in very good shape. They are 22x11x8 10 paddle SLS 72 rollout. I am selling the tires only for $300.00 shipped
  8. Accepting reasonable offers
  9. 2 - 3.5 x 6 kn filters for 34mm carbs they fit 2 1/4 carbs. $35.00 shipped A swinger bolt with pivot tube and end caps with seals. Will also throw in a steering stem bearing and seals. $40.00 shipped A Modquad brake backing plate with the c-clip. Also has brake spacers, but they r from jjanda so I don't know if they will work. $25.00 shipped Front fender mounts powder coated a blue with green and some other flakes in it. $10.00 shipped Rear 6 bolt steel sprockets either sunstar or jt. $20.00 shipped each $15.00 a piece if you buy more than 1. I have 3-45, 2- 46 , 1-48 Rectifier you can have it if you buy something or pay the shipping.
