mudkickin4x4
About mudkickin4x4
  • Birthday 03/23/1990
Contact Methods
  • AIM
    horsecrap1529
    hot spring,ar
    2000 banshee, t-5s, jetted,
mudkickin4x4's Achievements
  1. Needs a left upper A arm!!!
    1. FullThrottle_06'
      FullThrottle_06'
      saw one on e-bay last night. fyi
  2. ok i let it sit with gas off for a day and still wont start. I cleaned the plugs again and it cranked on the 20th kick with no choke out. Once it starts it runs great. Carbs dirty?
  3. good idea man. ill let you know
  4. Now i went out to ride it and no start again. I checked for spark and it was good. Ive noticed the carbs leak a nice puddle of gas out overnight, guessing a needle is stuck? Could that cause it not to start? Or could TORS still be causing it. Im gonna do a compression test tomorrow but my engine seems to be very strong. Always cranked on first kick until now. Also i will add that when it wouldnt start after about 20 kicks i could get it too run and it ran great
  5. I disconnected the Tors and it started right up. Parking brake was already disconnected. Now whats the difference between disconnecting the Tors and buying a Tors kit to remove it? Besides making alot of room
  6. I bought this 04 LE banshee about a month ago. It runs awesome, motor feels very strong and always started on first kick. Went riding a few days and went i got home to put it in the garage, no start. I got it in the garage and cleaned the plugs, put them back in and it started on like the 7th kick. Anyways went out this morning and no start. Pulled plugs and cant see spark. Also, i might add the first time it wouldnt start i couldnt get the choke to stay out??? All banshee has is full fmf system. Still has TORS(Problem maybe?)
  7. Im interested, just wanna know $$$$$
  8. Forgive me for asking this. But my banshee seems to idle a little faster than it should. Where is the idle screw to adjust? I DO have TORS
  9. ok then its full. Just making sure it wasnt suppose to be to the top. I just recently got it and trying to check everything out on it
  10. How full should the crankcase be with fluid? Everything is lubicated but i cant see the fluid level. Clutch is being weird too (seems kinda weak and wont roll in gear with the clutch in) Can i run a light duty 10w40 if i need to change it?
  11. The guy i got it from said he mixed lucas 2 stroke 40:1, that about right? Im somewhat mechanicly inclined but i might drop it off at a local shop and let them look it over
  12. I guess i have a few questions. Sometimes after sitting for a day or so it takes a while to get it started (like 7 kicks), Is that just because it a 2 stroke? Also ive noticed the engine gets hot somewhat quickly (like 10 minutes of hard riding) Anything to be alarmed about? It has no motor mods but a full fmf system and a boost bottle, but nothing internal
  13. I just got me a 04 special edition banshee. I was just wondering if anyone has some advice for me as in upkeep on it? Any symptoms i should look for before something goes out? I want to take care of it the best i know how
