I've searched, but can't find what i'm looking for. I'm kinda lost here. Here's my mods: Stock top end, T5's, ready filter and no snorkle. My elev. is around 700ft and it's around 50-75 degrees right now. I still have the TORS connected. I know, i gotta get rid of it....
I just installed my T5's(thanks NYUK!) this weekend along with new main jets. I bought 270's, 280's and 290's. I put the 280's in so i'd have room to adjust up or down. I sprayed down the inside of the carbs with carb cleaner while i changed out the jets.(had 220's in it) It ran great before with the stock pipes. When i first cranked it up, It acted really funny. The left side sounded great, idled fine, but the right side kinda sounded like it was only firing half the time. This was at idle and all the way up until the powerband hit, then all was well. So i synced the carbs with the idle knowbs on the tors and played with the air screws (actually runs best with them all the way in!) and it seemed to fix the problem, only now it idles really high, but not all the time. When i set it, the idle was fine, then i went out riding for awhile and it would idle really high when i stopped. It will go down to normal idle if i put it under load and lower the rpms(let out the clutch with the brake on, without any throttle) and it will stay that way til i rev it again, then it's back up to the high idling. I tried adjusting the idle knobs down and it kills the motor as soon as i turn them. Can anyone figure this out for me? I rode for about 2 hours like this, probably not the smartest thing, but thost new pipes are wicked. Just gotta figure this idle thing out. Could i need a bigger pilot? Do i need to move my needle jet? Is it something else? I'm not good at figuring out carbs, so help a brother out!
