took off stock carbs for cleaning,took off float bowl on first carb and removed main jet,there is a brass washer that comes out,well.......i tried to tap the washer out,later discovering that you dont tap it out,but pry it out!!from all the tapping i beveled the brass washer,thinking it was ok,put it back together,now that cylinder doesnt run!!!!my question is,is this washer act as a seal,beacause that i beveled it out so much,it appears that fuel can go right around the main jet up into the carb causing the one cylinder to suck way too much fuel.as i pulled the plug to see what it looked like,it was soaking wet,and im getting great spark,is this cylinder getting too much fuel beacuse the main jet washer is damaged
