Izord
Everything posted by Izord
  1. Matching sand tires and wheels. Kenda Dominators (22x11.00-10 rear) and I ITP Sand Stars (AT22x8-10" front) on Douglas Wheels https://imgur.com/a/GHKzKD4
  2. For sale is my 2001 Banshee that I’ve owned since new. Lightly ridden off and on for about 10 years — low estimated total chassis hours. Always well maintained. Key Build Specs: Patriot Racing 75HP dune port by Dan Bottom end balanced by Dan at Patriot in 2002 Top end freshly machined by Lake's Motorsports with .020 over 64.5mm Wiseco forged pistons – Maybe ridden 10 hours since then Coolhead with NOS/Pro Design-style domes Dyna FS programmable CDI Toomey T5 pipes, recently repacked silencers. 28mm Keihin PWK carbs with plenty of jets. Well tuned for here. Magura hydraulic clutch Lock-up clutch with adjustable arms Brembo front brake Full long travel suspension: Long Travel A-arms, DuraBlue +6" rear axle, Elka Stage 5 front & rear shocks (full compression & rebound adjustable), Elka System 5 steering damper Extended steering stem with damped bars. New tires: Front 23x7-10, Rear 22x12-9 SunF aggressive tires with DWT rim covers DG race pegs & nerf bars, DG six-pack rear rack, DG front bumper New 5.1 gallon plastic tank Floated stator, Trail Tech regulator/rectifier, bright LED lighting Billet clutch cover + billet stator cover Extras Included: Full spare sand tire/wheel set: Kenda Dominator 22x11-10 rears + ITP Sand Star 22x8-10 fronts on Douglas wheels (excellent condition) Complete Nitrogen cylinder + regulator + stainless steel hose for charging the Elkas. Original blue plastics with wear and sticker (solid and straight, easy to refresh). Everything else on the bike is sorted and performance-focused. This is a complete, turn-key 70HP dune rocket that runs well. Strong first-crank starts, crisp power delivery, and planted handling in the sand. Located in Las Cruces, NM. Local pickup preferred with cash/test ride. Serious out-of-state buyers welcome with deposit and video verification. Shipping available at buyer’s cost. Asking $13,500 OBO Serious inquiries only. Feel free to message with any questions. Coldstart from two different angles.
  3. OK, I just got the $12 ebay Chinese Yamaha R1 Mastercylinder, and it's the same as the other cheap one I got that was supposed to be for a Banshee. So now I'm thinking about getting the Brembo R1 or R6 mastercylinder. You think it's gonna have a bigger piston? That's what I want.
  4. Bruh I looked at that Race Tech brembo caliper. It is sweet. But I'm good on my caliper, I just want a beefier master cylinder. I ordered a cheapass $12 R1 Master cylinder to check the bolt pattern, and if it fits I'll order one of the Brembo R6 master cylinder used off ebay and a rebuild kit maybe.
  5. Yeah, it got really flooded right before I took the jugs off then I rags in there around the rods and there was still some really oil gas in there. The engine's in the bike bruh, sitting on my front step, how I'm gonna fill it with gas, slosh and dump it? 🤣 That's why I had to suck it out with some fuel tubing, it was all good when I just used my cheeks, but at the end I was trying to suck the oil bubbles out and accidentally huffed some pretty nasty premix. One friend said I should be good unless it was like half full.
  6. I want to upgrade my rear master cylinder and I can't really find a better one than oem, I just have a crappy aftermarket one right now, but I put on the dual piston rear caliper from zoom zoom parts and I want a beefier master cylinder. I can't really find replacements that say how big the cylinder is, like for the front it's easy to find 15, 17 and 19mm master cylinders. But if this R1 or R6 Brembo will fit the bolt pattern I'll be good.
  7. I want to put my cylinders back on after I got them bored out and there was still a few tablespoons of oil/gas in the crankcase that I sucked out with some hose. Think that's good enough and I can put my cylinders back on?
  8. Yeah, just got a stuck ring a few weeks ago, and I wanted to ride.
  9. I just got 'em back. Bored 64.50 and Wiseco's.
  10. Now I have to do some work on it. I said low hours in the first post because I got it new and didn't take it out much. I replaced the original tires after a few month twenty years ago, and those replacements still have most of their tread. Took it to little Sahara once and local trails and lake dunes probably like 15 times. Also have another set of paddle tires I'd swap out for the Dunes, so they shared some wear, but they still look new. The original brake pads hardly had any wear. I just replaced them with YFZ450 brakes. But I ran it enough it has a stuck ring and light marks on the cylinder and lightly scuffed pistons. I lost 20 pounds of compression on the left cylinder last week after like a one hour ride then it wouldn't start after getting flooded the next day, so I pulled the head and saw the stuck ring. It was a dune port with 19cc domes on race gas. Then it had VF2's, but when I checked them, one of the reeds was starting to fray, so it had enough wear. So I gotta do something. Hopefully not having to buy new carbs. I'd rather get a stroker crank. Can I run those Assassin cylinders on 28mm Keihin PWKs? What's the biggest displacement I can run with my carbs bruh? Hey thanks for the answers before!
  11. I pulled the cylinders and they don't look too bad, but I think that ring just stuck yesterday because last week I had 130 psi, and after riding yesterday it's down to 105. These were new pistons and new stock bore cylinders that I had ported a couple years ago, just time for a rebuild or something. I might get some new cylinders, but wondering is it possible to bore these out? Any options with nikasil cylinders that wore out?
  12. Hey, I have an '03, with low hours on a Dune ported motor that I sent to Dan at Patriot racing 15 years ago. He welded and balanced the crank, put a 70hp dune port, lockout clutch, Noss Head with like 21cc domes, (125psi at 4000ft), and I have T5s and 28mm Keihin's, and a Dyna FS CDI. It's stock bore. I just woke it up after setting 10 years in a barn. Could I put a 4mil crank with domes or a spacer plate now, then next season put like Cub or Assassin 68mm cylinders? Thanks.
