Syclone2530
Everything posted by Syclone2530
  1. Yep, Took out the left side reed block and found one of the petals had been twisted and pushed back through where it was not supposed to go. Thanks all!
  2. I have a weird problem, only the right cylinder is running and while it is running I can put my hand over the back exhaust muffler on the non-running left side and it will suck my hand to it...it is pullin a vacuum back through the exhaust. Stats: 1998 Banshee Good spark both sides - when switched does not follow No work done prior to failure Spraying wd-40 into left carb will not make it fire 115 left and 120 rt compression Tors removed for years Ignition switch jumped/removed Stock carbs with 350 mains and .30 pilots FMF pipes w/Spark Arrestors Ported Has ran fine for years with these mods. Stock airbox with lid - no snorkle I think I will go after the reeds first...they are boyson, but are several years old. Thoughts on the Exhaust pulling a vacuum?
