highroller355
Everything posted by highroller355
  1. thanks guys i was onna be pissed if there was something wrong already
  2. all new clutch components hinson basket just built a 4 mil long rod with alot of porting 60or 80 over milled stock head i dont think a ton of power but feels preety good
  3. stays still at idle but when revving to get read to race it starts inching foward
  4. sorry man didnt put on there but looking for yfz rear tires but how much you looking to get for the front rims
  5. had to pass on it ,looking for 2003 and newer for brake light wire
  6. front brake lever with master and wire and rear brake switch or actuator what ever you want to call it brake light and maybe wiring harness
  7. front brake lever with master and wire and rear brake switch or actuator what ever you want to call it brake light and maybe wiring harness
  8. thanks woodro77 let me know if your friend is not gonna use or do you know where i can look at a wiring diagram my friend made the harness thats on the bike he might be able to make one for this also i would probably need to bring him the diagram and if any one has these parts
  9. is there anyway to tap into my harness and use some kind of trigger or something on the front brakeor i can use the newer style equipment and tap into my harness
  10. i need a new master and brake lever thinking of going with 2003 or newer with the brake light wire so i can run a brake light how hard will this be and does anyone have diagram which wire or anything
  11. my buddy has an 06 banshee stock carbs with 340 main stage 2 needle kit from dyna jet stock pilots clip set at 5th position have alot of porting and a milled head fmf fatty pipes with power core silencers and power lid just got porting done put it back together with this set up and if i hit th throttle lightly the rpms stay up tap it againa and it comes down to perfect idle it only happens when i give it a little gas could this be his needle hight or pilots or do you think his carb or carbs might be hanging up
  12. my buddy has an 06 banshee stock carbs with 340 main stage 2 needle kit from dyna jet stock pilots clip set at 5th position have alot of porting and a milled head fmf fatty pipes with power core silencers and power lid just got porting done put it back together with this set up and if i hit th throttle lightly the rpms stay up tap it againa and it comes down to perfect idle it only happens when i give it a little gas could this be my needle hight or pilots or do you think my carb or carbs might be hanging up
  13. how much for the dunlops to end early
  14. they still make raltors just have to look usually around 75-85 each i also found them for around 65 each
  15. lol ya i just went with a round house set up,sold the carrier today and i got a stock head or my other motor
  16. looking for stock head front brake lever with master ,kenda tires or stock yfz doesnt have to be even i will send cash or paypal or you can send me i also have stockswing arm
  17. yo your from nyc and worried about snow tires lmfao to funny incase you havent noticed we aint getting snow
  18. i was looking to get $100, the j arms not sure they were on the bike when i bought it but i will try to find out for you
  19. why did you have to weld the bolt mine cleared no problemall i had to do is make 2 brakets to brace the air box i did no special work and i didnt have to buy any special boots
  20. make offer bearings and seal in good cond
  21. im gonna use the stock but will be calling you thanks bought my last one from you
