byebyeshee
Everything posted by byebyeshee
Excellant OEM parts left for sale...
byebyeshee replied to byebyeshee's topic in For Sale - Parts & Accessories
I hope your the guy that emailed me and is sending a money order? I don't check this site, you guys have to email me if you want something. -
These parts are all from a 2000 Banshee that was stored since 2002. I parted out EVERYTHING and whats left here is all I have left, NOTHING ELSE. I do accept PAYPAL as long as you add the 3% fee and my Paypal address is [email protected]. I am much better at replying to a direct email rather than a PM, please email [email protected]. Everything is in excellent shape, no paint touch up, no cracks, no welding and all have very very little wear. Banshee had very little ride time and came from the South. Everything is clean clean clean. I will combine shipping but these prices DO NOT INCLUDE SHIPPING UNLESS STATED. I am pretty firm on the prices, but I'll take a few bucks off for multiple purchases. I will take any picture you want. Shipping - They are mostly light parts for 6-10$. Swinger, A arm, Nerfs - heavier stuff 10-20$. 30$ Clutch cover with WP and WP cover and dipstick - One small scrub from pedal - Excellent candidate for Powder coating. 10$ Stator cover and gasket. 25$ Metal nerfs. Surface rust from sitting - No bends - Great shape. 25$ Skid plate - Very straight - One small rock mark underneath by rotor guard. 45$ Swingarm and Dogbone - Excellent paint!! OEM - All good bearings - Very little scratching. 20$ Left lower A arm - Perfectly straight, no accidents - With bolts - BJ needs boot I ripped it storing it - no play. 5$ Chain adjusters. 25$ Sprocket hub with nuts and locking rings. 30$ Rear Rotor and hub. 5$ Coolant resevior tank and gasket and cap. 20$ Footpegs straight. 55$ Flywheel in perfect shape. 30$ Rear hubs. 30$ Front hubs with rotors and perfect bearings. 25$ Intake boots - NO CRACKS - 1 reed block - both rear rubber boots and mounting plate. 25$ Kicker gear assembly and idle gear 45$ Kicker - NO PLAY - VERY TIGHT. 15$ Rear brake pedal and shift pedal. 20$ Left A arm spindle - you need to verify it is a left side. 20$ Shift shaft - Perfectly straight. 35$ On/Off switch - next to new - with voltage regulator and small black box. 25$ Motor mounts - ALL mounts - 2 exhaust hangers with SS screws and any other bracket it had. 10$ Air Box cover and clips. 20$ Hard and soft fr brake lines - Splitter - Clutch cable and I think it is the P Brake cable. 15$ Petcock and bag of clips, clamps, grommets,throttle springs, coolant tube - whatever it had..... SHIPPED PRICE 30$ Radiator - Only part not shown I believe has all hoses and cap. DON'T PM ME, USE MY EMAIL! PLEASE! EMAIL and PAYPAL - [email protected] Thanks for looking. This sites uploading file size is pitiful.......................
Great condition 2000 Banshee parts for sale.
I'm gonna offer it at 55$ shipped for awhile, unless someone wants a few other items with it. Thanks -
All I have left is stock parts from a 2000 Banshee that was ridden for 2 years and then stored. I also have some 98 Banshee parts that aren't very clean but cheap, email me if your broke..... Not in this list!! These parts are CLEAN CLEAN CLEAN. I will combine parts and save you some cash on shipping. I am fairly firm on everything unless you combo up like kicker and kicker gears and idler gear etc etc. Everything includes ride unless stated and I have closeup pictures of all the parts. Please email or Paypal [email protected], tell me what forum you read this at and what your user name is. Here is the list and some of them are gone. *************************************************************************************** Front hard brake lines, flex lines and T with line to master 25$ Swinger, dogbone and adjusters 30$ PLUS RIDE Stock black bars 20$ Metal Nerfs - some surface rust from not being used 30$ Airbox, lid and back of carb boots 30$ - Will sell just lid or boots. Left lower Aarm, no boot - got tear when moved around shop - tight bj 32$ Radiator with all lines and metal adapter from clutch cover 35$ Clutch cover, WP, WP cover and dipstick 35$ Stator cover and gasket 20$ Rear skidplate - straight and rock damage free - surface rust from sitting 25$ Flywheel 55$ Chain guides 10$ Footpegs 25$ Coolant resevoir, cover and gasket for fender 5$ Plus ride or add to other.... Left spindle 25$ Coil 25$ Super nice on/off switch 25$ Regulator 10$ Tight kicker 40$ Kicker gears and shaft etc and metal idler gear 30$ Shifter and rear brake pedal 20$ Shifter shaft 20$ Seat latch 12$ Rear brake rotor and hub 30$ Rear sprocket hub and lock ring 30$ Front hubs and rotors - good bearings 42$ All motor mounts and 2 pipe hangers 25$ 2 intakes, one reed - perfect rubber - perfect 22$ Throttle springs 8$ shipped or 4$ with something else Parking brake and clutch cable 17$ TRADES?? I need a nice clean tight Banshee or other front master cylinder and a left perch with lever also clean and tight. Also 1986/87 ATC200X, ATC350X parts.............
I'm asking 40$ shipped for this throttle, Cable and Tors. Throttle has all stainless steel bolts. Cable is stock OEM with low hours with no damage or frays. [email protected] for Paypal or Pictures Still have the following parts, all in excellant condition with less than 2 years of use. These parts are in great shape and my prices are cheap and are right there with lesser quality parts. Make me an offer based on what you want to pay and add 6$ to ship for light/small parts and about 12$ for larger and heavier parts. Rear hubs Front hubs with rotors and good bearings and seals Rear sprocket hub and lock ring Rear brake rotor and hub All motor mounts and links and other mount, 2 pipe hangers Flywheel Left spindle Left lower a arm - rubber ripped from moving around my shop - ball joint is tight, arm straight Clutch cover with wp and wp cover - sale pending Swinger and dogbone White rear shock - I may keep this Stator cover Nice not sloppy kicker and shift lever and rear brake lever - sale pending on kicker Kicker gears, shaft and idler gear Coil - on/off switch - volt reg and other elec box Chain adjusters and chain sliders - will sell with skid plate or swingarm Metal heel guards and foot pegs Mint throttle with SS hardware and cable 2 intakes no cracks and 1 reed block Airbox and snorkel with lid Clutch cable and p brake cable Rear skid - surface rust - no thrashing Tank petcock and every grommet or clip/clamp that was on the Banshee
This is the end of the nice BANSHEE parts....
Thanks... Fenders, swing arm bolt, seat latch - sold -
Glad you found one, I just don't get on here fast enough or frequently.... -
Sorry, don't come here often. The intakes are perfect, stock and not modified. Clutch cover is a great bargain. Anyone who wants anything can paypal [email protected], but please list the part and a good address, thank you!! -
I'm getting down to the end of this low hour very clean machine. Prices are shipped, email [email protected] for pics Prices include shipping and I ask you to pay the PAYPAL and fee to ([email protected]). These prices are fairly firm, they are right there with parts that aren't nearly as nice and I just want them GONE!!!!!!!!! ***********TRADES************* I could use a NICE AND TIGHT clutch lever assembley and front brake master cylinder with straight tight lever from newer BANSHEE - will trade something.... Also 200X, 350X Honda ATC parts are always welcome. Rear hubs 40$ Front hubs with rotors and good bearings 45$ Rear sprocket hub and lock ring 30$ Rear brake rotor and hub 30$ Stock rear blue fender and cut front, very nice with all labels and OEM stickers 95$ shipped - My shipping cost is alot... All motor mounts and links and other mount and 2 pipe hangers 25$ Flywheel 55$ Left spindle 20$ Left lower a arm 30$ - rubber ripped from moving around my shop - joint is tight, arm straight Clutch cover with wp and wp cover 35$ Swinger and dogbone 50$ - will cost me 15$ to ship White rear shock 80$ Stator cover 15$ Nice not sloppy kicker and shift lever and rear brake lever 50$ Kicker gears, shaft and idler gear 30$ Coil - on/off switch - volt reg and other elec box 50$ Swing arm bolt - great and chain adj and chain sliders 25$ Metal heel guards and pegs 50$ Mint throttle with SS hardware and cable 35$ 2 intakes no cracks and 1 reed block 20$ Airbox and snorkel with lid 25$ Seat latch 10$ Clutch cable and p brake cable 12$ Rear skid - surface rust - no thrashing 22$
Both rear hubs, Sprocket hub with locking collar and the brake rotor with hub 100$ shipped. Everything is in very good shape with good splines and straight. [email protected]
Nice stock kicker + guts and shifter F/S
byebyeshee posted a topic in For Sale - Parts & Accessories
Kicker in great shape - not sloppy and gear shift lever - straight for 45$ shipped Another 25$ and I'll add the kicker gears, shaft and all it's related parts and the idler gear. with thrust washer and clip etc. from behind the clutch cover. 40$ for clutch cover with a good low hour waterpump and the plastic cover too. Thanks.... -
I'll take any picture you wish if you email me at [email protected] Every part is very good to great, no dissapointments. ALL PRICES ARE SHIPPED, Money orders or if you want to use PAYAL you add the 3% Paypal fee. Frame with bill of sale, never crashed 270$ Cases seperated with plastic hammer excellant 175$ Complete Tranny and all shift parts 175$ Front hubs, good bearings and straight rotors 45$ Rear hubs 40$ Foot pegs 22$ Foot metal nerfs 35$ Stock Bars 20$ Sprocket hub and lock ring 35$ Rotor hub and straight rotor 35$ Swinger, dogbone and chain slides 45$ Clutch cover and W-pump and cover 35$ All motor mounts and 2 pipe hangers 25$ Swing bolt and chain adjusters 22$ Air box, lid and rear intake rubbers 28$ Clutch and pbrake cable 20$ Flywheel 50$ Coolant resevoir 10$ Great rear Blue plastic and cut front 100$ Stator cover and gasket 20$ Tight kicker and gears and shaft/spring etc 45$ Shift and rear brake lever 25$ Coil 25$ 2 intake rubbers no cracks, clamps and 1 reed block 22$ Seat latch 12$ Great throttle, TORS and cable 35$ Radiator 30$ Rear shock 75$ Rear skid, not thrashed 20$ Left Aarms and spindle 70$
2000 throttle with cable in great shape 35$ shipped Caps TORS too if I still have it..
Have a 2000 bumper with rubber caps. 30$ shipped
Have a 2000 tranny complete with all shift parts from low hour shee. 175$ shipped
I have the rotor and hub off of 2000. 35$ shipped
I would like to score a stock set of rear 400EX rims or other 9" Honda pattern aluminum rims and stock 300EX, 400EX or 450R rear hubs with lug nuts. I really need just rims, but could use rims with tires mounted on them too. These parts are for my Honda ATC's so there are some 200X or 250SX parts I could use also. To trade or sell, I have alot of 2000 Banshee low hour parts to trade. This Banshee was not beat and ridden very little, then parked indoors for years. I have no need for any Banshee parts. Nothing is bent, cracked welded or worn out. I must have pictures from you and will do the same for you, also please have some feedback or a bit of posts. I've been ripped off twice lately, once on EBAY and once privately. I have EBAY feedback and other FB on another ATC message board. I'm in Mass for shipping purposes. Thanks for any help!! Off the top of my head, I have the following items to sell or trade - Rear hubs. Front hubs with discs. Great rear fender OEM Blue. Great cut front fender. Straight nice frame. Tranny. All shifting parts. Kicker. Shifter. Coil. Cases. Both case covers. Stock bars. Pegs and metal nerfs. Rear shock. Air box. Throttle and TORS. Left A arms. Front soft, hard brake lines and splitter. Intakes with 1 reed assm - no dry rot. Front bumper. Rear swinger. Swingarm bolt and adjusters. Dogbone. Swinger guard. All cables. Flywheel. Rear sprocket hub. Rear rotor and hub. Rear brake pedal. Chain sliders. Motor mounts. I think thats all that is leftover....
I'll just take a wild stab at it, and say that he probably is looking for Banshee's in the 1500$ and under range.....
Great 2000 Bansee parts F/S
Yes, please just email me at [email protected] and I'm certain you'll like the parts. I try posting pictures here but I have to shrink them to almost nothing just to post them so I'd rather send you or anyone else the pics through email. I'll try posting one here...... It will probably be so dam small it will be useless. Am I just stupid or is there a way to post a few nice clear large pictures on here????? -
There from a 2000 low hour Shee and all in very good or better shape. Parked in 2002 when owner died, I got it 6 months ago just to part it out for $ the 350X project. I'll try and list some of them, prices are shipped. Rear hubs 40$ Front Hubs and discs 40$ Left A Arms and spindle 70$ - rubber on bj is torn from moving around shop Rear sprocket hub 30$ Rear disc and hub 35$ Great Frame 285$ shipped Bill of Sale. Cases 190$ Tranny and all shift parts 185$ Great kicker and shifter 45$ Rear skid with 2 chain slides 30$ Stock bars 15$ Clutch cover nice with good water pump and stator cover 50$ Kicker guts and idler gear 25$ Pegs and nerf steels 50$ Nice Throttle and cables 30$ Flywheel 55$ Front bumper 30$ Great OEM Blue rear fender 80$ Front OEM Blue cut 35$ Nice swinger and dogbone good bearings 45$ Rear shock 75$ Reed boots and one reed cage 20$
This is nice plastic from a 2001 Banshee. The rear fender is not cut and in great shape, all stock stickers and labels in great shape and just some stess marks. The front is CUT and in good shape with great stock stickers, only flaw is someone lightly scratched in the letter BBB into it but it is hardly noticable (initials??) 125$ shipped - firm, it will cost me alot just to ship this oversized pacakage and you will be happy to get these.
All parts from a 2000 Banshee parked in 2002, all parts are in great shape. RPM Dominator Axle - not cosmetically perfect, chrome is pitted - axle is perfectly straight and has perfect splines with all nuts and spacers 38 1/2 inches end to end. 200$ shipped Rear hubs 55$ shipped Front hubs with good bearings and rotors 50$ shipped Sprocket hub with good splines 35$ shipped Brake rotor and hub 35$ shipped Left A arm both with spindle assembley - rubber boot is torn from being moved. Balljoints are tight 90$ shipped. Tie rod with good ends and boots 25$ shipped. PAYPAL is [email protected]
Trade or sell 2000 Shee parts for Honda ATC parts.
The frame is in great shape, no welds or breaks. Top key sw mount got tweaked from being stored on it's back. I bent it back by hand , just want to disclose everything. Bottom has scratches but no major rock bashing. It will cost about 85$ plus to ship from MASS. I will provide a bill of sale.
